[OpenLayers-Users] Unable to understand the Initialize code?
Smaran Harihar smaran.harihar at gmail.com
Thu Aug 9 10:21:55 PDT 2012
Hi Phil,
Thanks for the reply. No i do understand javascript. What I did not
understand in http://dpaste.de/t214A/
was the 'arguments' variable which was passed in the prototype,
OpenLayers.Control.prototype.initialize.apply(
            this, arguments
Also, what does 'options && options.handlerOptions || {}' mean in,
this.handlerOptions = OpenLayers.Util.extend(
            options && options.handlerOptions || {},
            this.defaultHandlerOptions
And finally what is the significance of including this,
 CLASS_NAME: "OpenLayers.Control.Click"
Thanks,
Smaran
On Sun, Aug 5, 2012 at 3:12 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
>  i am trying to understand the initialize code in the link<http://dpaste.de/t214A/>
>  It is encapsulated in the OpenLayers.Click command,
>  OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, { link<http://dpaste.de/t214A/>
>  I am not able to understand what exactly the initialization code is
> doing and what 'this' implies?
> First, you dont need to understand this to use it. You would work with
> this in openlayers by manipulating openlayer.control properties. This is
> code for creating a new descendent of an openlayers control. The kind that
> live in openlayers/lib/control.
> If you havent worked with OO languages, this probably isnt the best place
> to start.
> Anyway, the basics of it are to create a new descend of the
> openlayer.control class. when your code does a myvar = new
> Openlayers.control.click, then the initialise code is called. "this" is the
> way you refer to owner of the function - the specific instance of the
> class. What the code does is:
>  - combines the various options into the handleroptions property.
>  - call the prototype (Openlayers.control) initialize method
>  - set the handler property of the handler to be a new instance of the
> openlayers click handler control, using the handleroption property.
> A javascript language reference text would be a good place to go. The
> openlayers list isnt really a place to learn javascript.
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120809/5b7a7ee3/attachment-0001.html>
