[OpenLayers-Users] Unable to understand the Initialize code?
Phil Scadden p.scadden at gns.cri.nz
Thu Aug 9 18:40:40 PDT 2012
> was the 'arguments' variable which was passed in the prototype,
Standard javascript. See
http://www.sitepoint.com/arguments-a-javascript-oddity/ for more
explanation.
> Also, what does 'options && options.handlerOptions || {}' mean in,
This says "if options is not null and options.handlerOptions is not
null, return options.handlerOption, else return an empty object". Think
about how a null object works in a boolean expression in JS. This
ensures an empty object rather than a null is passed to the Extend
function, which combines it with the defaultHandlerOptions. The code
intent is to combine any passed in handler options with the default
> And finally what is the significance of including this,
>  CLASS_NAME: "OpenLayers.Control.Click"
JS lacks a formal class structure. Any functions can serve as template
for creating objects. Openlayers way of creating  a simple class
structure can be found in Class.js code.
Part of the convention is to add property CLASS_NAME to function
designed to be an OL class with the class name in it.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
