[OpenLayers-Users] connect db through sqlalchemy
Christian Ledermann christian.ledermann at gmail.com
Wed Aug 15 01:55:38 PDT 2012
have a look at:
http://www.mapfish.org/
or http://papyrus.readthedocs.org/en/latest/
or http://geodjango.org/
note this list is non exhaustive there may be other solutions that i missed
On Tue, Aug 14, 2012 at 9:10 PM, Gery . <gamejihou at hotmail.com> wrote:
> Hello list, someone knows how to connect a PG database through sqlalchemy
> with OL?
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO
> es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie
> NICHT, wenn es NICHT notwendig ist.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
