[OpenLayers-Users] connect db through sqlalchemy
Gery . gamejihou at hotmail.com
Wed Aug 15 02:45:15 PDT 2012
Thanks Christian, these are very nice solutions, I checked the Rest services used in Mapfish as well its protocol, it's a great job indeed. I think I found the solution, please correct me if I'm wrong, but to do the connection I have to tell Apache (I use that) that understands and executes python scripts, this is with mod_wsgi, I did some tests and this works, so I just need to play with the OpenLayersHTTP protocol to pass JSON/GeoJSON info from OL to my PG database, I know I have to use the "url" provided by ExtJs to do the link, but I have to get that.
Thanks again,
Cheers,
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 15 Aug 2012 11:55:38 +0300
> Subject: Re: [OpenLayers-Users] connect db through sqlalchemy
> From: christian.ledermann at gmail.com
> To: gamejihou at hotmail.com
> CC: openlayers-users at lists.osgeo.org
> have a look at:
> http://www.mapfish.org/
> or http://papyrus.readthedocs.org/en/latest/
> or http://geodjango.org/
> note this list is non exhaustive there may be other solutions that i missed
> On Tue, Aug 14, 2012 at 9:10 PM, Gery . <gamejihou at hotmail.com> wrote:
> > Hello list, someone knows how to connect a PG database through sqlalchemy
> > with OL?
> > es necesario.
> > Users mailing list
> > Users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Best Regards,
> Christian Ledermann
> Nairobi - Kenya
> Mobile : +254 702978914
> If you save the living environment, the biodiversity that we have left,
> you will also automatically save the physical environment, too. But If
> you only save the physical environment, you will ultimately lose both.
> 1) Don’t drive species to extinction
> 2) Don’t destroy a habitat that species rely on.
> 3) Don’t change the climate in ways that will result in the above.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120815/ed2c85cb/attachment.html>
