[OpenLayers-Users] WFS-T: Delete Feature works, edit or create Feature does not work
Peter Lanz peterlanz at yahoo.com
Thu Aug 16 09:20:57 PDT 2012
Thank you very much for the hint Bart!!! - loadin the legacy.sql definitions solved the problem ... regarding the wfs-t from gistutor.com
Unfortunately, the openlayers demo "wfs-t.html" still won't work. Same picture as before I get the "Success" message but after reloading all changes are gone. The data for both wfs-t services are saved in the same database. this was installed automatically with the postgis v2.0 extension and is called "postgis20". maybe apart from legacy.sql which I just loaded, there are some more definitions missing?
kindly,
pedro
peter lanz
 00491632465592
 berlin
 flasherei.net
> From: Bart van den Eijnden <bartvde at opengeo.org>
>To: Peter Lanz <peterlanz at yahoo.com>
>Cc: "openlayers-users at lists.osgeo.org" <openlayers-users at lists.osgeo.org>
>Sent: Thursday, August 16, 2012 11:59 AM
>Subject: Re: [OpenLayers-Users] WFS-T: Delete Feature works, edit or create Feature does not work
>My best guess is that you need to load the legacy.sql into PostGIS, see also:
>https://getsatisfaction.com/opengeo/topics/unable_to_edit_the_geometry_of_postgis_layers
>Best regards,
>Bart
>OpenGeo - http://opengeo.org
>Expert service straight from the developers.
>On Aug 16, 2012, at 11:54 AM, Peter Lanz <peterlanz at yahoo.com> wrote:
>Dear OpenLayer Users!
>>I tried to set up a WFS-T using the tutorial at http://www.gistutor.com/openlayers/22-advanced-openlayers-tutorials/47-openlayers-wfs-t-using-a-geoserver-hosted-postgis-layer.html. Doing so, I imported the shape files to postgresql (9.1). I work with GeoServer 2.1.4.
>>Deleting features works well, but adding or editing doesn't! Same with the Openlayers demo "wfs-t.html" with the tassi datasets. When I use shapefiles instead of postgresql all works well!
>>I would very much appreciate some hints how to solve this. I tried to install and run GeoServer on Jetty, Tomcat6 and Tomcat on top of Apache HTTP but in all 3 cases the same error so maybe something went wrong while importing the shapefiles to the database!?
>>I get this "Success" message:
>>WFS-Transaction: Success
>><?xml version0"1.0" encoding="UTF-8"?>
>><wfs:WFS_TransactionResponse version="1.0.0."
>>xmlns="http://opengis.net/wfs"
>>xmlns="http://opengis.net/ogc§
>>xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:8090/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd">
>><wfs:InsertResult>
>><ogc:FeatureID fid="new0"/><ogc:FeatureID fid="new1"/><ogc:FeatureID fid="new2"/>
>></wfs:InsertResult>
>><wfs:TransactionResult>
>><wfs:Status>
>><wfs:SUCESS/>
>></wfs:Status>
>></wfs:TransactionResult>
>></wfs:WFS_TransactionResponse>
>>...but after reloading the new features are gone.
>>Please let me know if any log data would help you to help me!
>>cheers
>>pedro
>>peter lanz
>> 00491632465592
>> berlin
>> flasherei.net
>> _______________________________________________
>>Users mailing list
>>Users at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120816/0deeefe1/attachment-0001.html>
