[OpenLayers-Users] Fw: WFS-T: Delete Feature works, edit or create Feature does not work
Peter Lanz peterlanz at yahoo.com
Fri Aug 17 03:10:44 PDT 2012
..and that is what pg_log says:
FEHLER:  Relation »public.gt_pk_metadata« existiert nicht bei Zeichen 15
ANWEISUNG:  SELECT * FROM public.GT_PK_METADATA
roughly translated:
ERROR: Relation does not exit at position 15
COMMAND: SELECT * FROM public.GT_PK_METADATA
>To: Bart van den Eijnden <bartvde at opengeo.org>
>Cc: "openlayers-users at lists.osgeo.org" <openlayers-users at lists.osgeo.org>
>Sent: Thursday, August 16, 2012 6:20 PM
>Subject: Re: [OpenLayers-Users] WFS-T: Delete Feature works, edit or create Feature does not work
>Thank you very much for the hint Bart!!! - loadin the legacy.sql definitions solved the problem ... regarding the wfs-t from gistutor.com
>Unfortunately, the openlayers demo "wfs-t.html" still won't work. Same picture as before I get the "Success" message but after reloading all changes are gone. The data for both wfs-t services are saved in the same database. this was installed automatically with the postgis v2.0 extension and is called "postgis20". maybe apart from legacy.sql which I just loaded, there are some more definitions missing?
>kindly,
>pedro
>________________________________
>peter lanz
> 00491632465592
> berlin
> flasherei.net
>> From: Bart van den Eijnden <bartvde at opengeo.org>
>>To: Peter Lanz <peterlanz at yahoo.com>
>>Sent: Thursday, August 16, 2012 11:59 AM
>>My best guess is that you need to load the legacy.sql into PostGIS, see also:
>>https://getsatisfaction.com/opengeo/topics/unable_to_edit_the_geometry_of_postgis_layers
>>Best regards,
>>Bart
>>OpenGeo - http://opengeo.org
>>Expert service straight from the developers.
>>On Aug 16, 2012, at 11:54 AM, Peter Lanz <peterlanz at yahoo.com> wrote:
>>Dear OpenLayer Users!
>>>I tried to set up a WFS-T using the tutorial at http://www.gistutor.com/openlayers/22-advanced-openlayers-tutorials/47-openlayers-wfs-t-using-a-geoserver-hosted-postgis-layer.html. Doing so, I imported the shape files to postgresql (9.1). I work with GeoServer 2.1.4.
>>>Deleting features works well, but adding or editing doesn't! Same with the Openlayers demo "wfs-t.html" with the tassi datasets. When I use shapefiles instead of postgresql all works well!
>>>I would very much appreciate some hints how to solve this. I tried to install and run GeoServer on Jetty, Tomcat6 and Tomcat on top of Apache HTTP but in all 3 cases the same error so maybe something went wrong while importing the shapefiles to the database!?
>>>I get this "Success" message:
>>>WFS-Transaction: Success
>>><?xml version0"1.0" encoding="UTF-8"?>
>>><wfs:WFS_TransactionResponse version="1.0.0."
>>>xmlns="http://opengis.net/wfs"
>>>xmlns="http://opengis.net/ogc§
>>>xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:8090/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd">
>>><wfs:InsertResult>
>>><ogc:FeatureID fid="new0"/><ogc:FeatureID fid="new1"/><ogc:FeatureID fid="new2"/>
>>></wfs:InsertResult>
>>><wfs:TransactionResult>
>>><wfs:Status>
>>><wfs:SUCESS/>
>>></wfs:Status>
>>></wfs:TransactionResult>
>>></wfs:WFS_TransactionResponse>
>>>...but after reloading the new features are gone.
>>>Please let me know if any log data would help you to help me!
>>>cheers
>>>pedro
>>>peter lanz
>>> 00491632465592
>>> berlin
>>> flasherei.net
>>> _______________________________________________
>>>Users mailing list
>>>Users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120817/c71ad5fa/attachment.html>
