[OpenLayers-Users] Strange behaviour renaming feature
David Alda Fernandez de Lezea dalda at hazi.es
Thu Aug 23 23:35:14 PDT 2012
 Hi list,
I'm having a strange behaviour while doing some operations. We've developed an application in which users will cut features and rename them. The problem is that after the user has cut the feature in two more features, for example, and he wants to rename one of the two resultant features, both features' label attribute is changed. I mean, from one feature I get 2. One is labelled as "A" and the other one as "B". The thing is that if I want to rename A to be C, then feature A and feature B get the same value for the label attribute i.e. C.
Any idea what could be happening?? Why is this strange behaviour?
Thanks in advance.
Regards,
Un saludo,
David Alda Fernández de Lecea
GIS Analista Programadorea / Analista Programador GIS
KONTSULTORIA  UNITATEA / UNIDAD DE CONSULTORÍA
Granja Modelo s/n
01192 Arkaute Araba
T 945 003 295 F 945 003 290
dalda at hazi.es | www.hazi.es <http://www.hazi.es/>
 <file://C:\Documents and Settings\u0899dal\Datos de programa\Microsoft\Signatures\HAZI Consultoria_archivos\image001.jpg>
<blocked::http://www.hazi.es/> *********************  LEGE OHARRA   *******************   AVISO LEGAL   *******************   DISCLAIMER   ******************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
