[OpenLayers-Users] Strange behaviour renaming feature
Alexandre Dubé
adube at mapgears.com
Mon Aug 27 05:28:36 PDT 2012
Try minimizing your code to find pin down what the issue is. Read
more about this :
http://docs.openlayers.org/help/minimize.html
HTH,
Alexandre
On 12-08-24 02:35 AM, David Alda Fernandez de Lezea wrote:
> Hi list,
> I'm having a strange behaviour while doing some operations. We've developed an application in which users will cut features and rename them. The problem is that after the user has cut the feature in two more features, for example, and he wants to rename one of the two resultant features, both features' label attribute is changed. I mean, from one feature I get 2. One is labelled as "A" and the other one as "B". The thing is that if I want to rename A to be C, then feature A and feature B get the same value for the label attribute i.e. C.
> Any idea what could be happening?? Why is this strange behaviour?
> Thanks in advance.
> Regards,
> Un saludo,
> David Alda Fernández de Lecea
> GIS Analista Programadorea / Analista Programador GIS
> KONTSULTORIA UNITATEA / UNIDAD DE CONSULTORÍA
> Granja Modelo s/n
> 01192 Arkaute Araba
> T 945 003 295 F 945 003 290
> dalda at hazi.es | www.hazi.es <http://www.hazi.es/>
> <file://C:\Documents and Settings\u0899dal\Datos de programa\Microsoft\Signatures\HAZI Consultoria_archivos\image001.jpg>
> <blocked::http://www.hazi.es/> ********************* LEGE OHARRA ******************* AVISO LEGAL ******************* DISCLAIMER ******************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
