[OpenLayers-Users] problem to do a simple button on a mobile map
Gilbert, Antoine
AGilbert at korem.com
Fri Aug 31 12:51:48 PDT 2012
Hi list
I'm just testing some mobile navigation
I have a map and a simple toolbar and in this toolbar I add a simple tool which just do an alert on the trigger method when user touch the button.
The problem I have: I touch the button, trigger is called, but, next touch anywhere on the screen will make trigger called again… I have no idea why, my example have almost no code…
I guess someone could easily tell me what is my problem?
Here is my button:
GeolocateControl = OpenLayers.Class(OpenLayers.Control, {
type: OpenLayers.Control.TYPE_BUTTON,
CLASS_NAME: "GeolocateControl",
trigger: function(){
alert("trigger");
Here is my complete test page
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
<meta name="apple-mobile-web-app-capable" content="yes">
<link rel="stylesheet" href="http://dev.openlayers.org/releases/OpenLayers-2.12/theme/default/style.mobile.css" type="text/css">
<link rel="stylesheet" href="http://dev.openlayers.org/releases/OpenLayers-2.12/theme/default/style.css" type="text/css">
<script src="http://dev.openlayers.org/releases/OpenLayers-2.12/lib/OpenLayers.js?mobile"></script>
<style>
html, body {
margin: 0;
padding: 0;
height: 100%;
#map {
position: relative;
width: 100%;
height: 100%;
</style>
</head>
<body>
<div id="map"></div>
<script>
var toolbar = new OpenLayers.Control.Panel({
displayClass: 'olControlEditingToolbar'
alert("trigger");
toolbar.addControls([
new GeolocateControl()
var osm = new OpenLayers.Layer.OSM();
osm.wrapDateLine = false;
map = new OpenLayers.Map({
div: 'map',
projection: 'EPSG:900913',
numZoomLevels: 18,
controls: [
toolbar
layers: [osm],
center: new OpenLayers.LonLat(0, 0),
zoom: 1,
theme: null
</script>
</body>
</html>
