[OpenLayers-Users] problem to do a simple button on a mobile map
Gilbert, Antoine AGilbert at korem.com
Fri Aug 31 13:16:15 PDT 2012
I think it's the alert itselfŠ It's probably disturbing some sort of
instructions sequence..
When I try with a console.debug (works on safari ios) I don't have the
problem..
Antoine
On 12-08-31 3:51 PM, "Gilbert, Antoine" <AGilbert at korem.com> wrote:
>Hi list
>I'm just testing some mobile navigation
>I have a map and a simple toolbar and in this toolbar I add a simple tool
>which just do an alert on the trigger method when user touch the button.
>The problem I have: I touch the button, trigger is called, but, next
>touch anywhere on the screen will make trigger called againŠ I have no
>idea why, my example have almost no codeŠ
>I guess someone could easily tell me what is my problem?
>Here is my button:
>GeolocateControl = OpenLayers.Class(OpenLayers.Control, {
>        type: OpenLayers.Control.TYPE_BUTTON,
>        CLASS_NAME: "GeolocateControl",
>        trigger: function(){
>            alert("trigger");
>Here is my complete test page
><!DOCTYPE html>
><html>
>    <head>
>        <meta http-equiv="Content-Type" content="text/html;
>charset=utf-8" />
>        <meta name="viewport" content="width=device-width,
>initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
>        <meta name="apple-mobile-web-app-capable" content="yes">
>        <link rel="stylesheet"
>href="http://dev.openlayers.org/releases/OpenLayers-2.12/theme/default/sty
>le.mobile.css" type="text/css">
>        <script
>src="http://dev.openlayers.org/releases/OpenLayers-2.12/lib/OpenLayers.js?
>mobile"></script>
>        <style>
>            html, body {
>                margin: 0;
>                padding: 0;
>                height: 100%;
>            #map {
>                position: relative;
>                width: 100%;
>                height: 100%;
>        </style>
>    </head>
>    <body>
>        <div id="map"></div>
>        <script>
>    var toolbar = new OpenLayers.Control.Panel({
>        displayClass: 'olControlEditingToolbar'
>            alert("trigger");
>    toolbar.addControls([
>        new GeolocateControl()
>    var osm = new OpenLayers.Layer.OSM();
>    osm.wrapDateLine = false;
>    map = new OpenLayers.Map({
>        div: 'map',
>        projection: 'EPSG:900913',
>        numZoomLevels: 18,
>        controls: [
>            toolbar
>        layers: [osm],
>        center: new OpenLayers.LonLat(0, 0),
>        zoom: 1,
>        theme: null
>        </script>
>    </body>
></html>
>_______________________________________________
>Users mailing list
>Users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/openlayers-users
