[OpenLayers-Users] buttonclick in trunk
Slawomir Messner slawomir.messner at staff.uni-marburg.de
Wed Feb 1 07:41:30 EST 2012
on our site www.regionalsprache.de/mapviewer/mapviewer.aspx we use
draggable controls. This worked quite well before buttonclick was
introduced. The user clicks the minimize/maximize button and the control
minimize or maximize, when the user holds the button pressed he can move
the control around(only the controls open on the left). On my dev
machine I use the master branch from git and now it's broken.
Clicking works on min/max-buttons but when I drag the map moves with the
control and now mousebutton events are also passed through controls like
the layerswitcher in:
  (old)
http://dev.openlayers.org/releases/OpenLayers-2.11/examples/osm-google.html
(new)
http://openlayers.org/dev/examples/osm-google.html
I can start panning over the open layerswitcher or doubleclick and it
zooms in (some users doubleclick when selecting layers even if single
click would do).
I don't have a completely working solution, so I would like to know if
it's a bug or a feature?
What I tried is to stop events on the div of the control (i.e.
OpenLayers.Event.observe(this.div, "click",
this.ignoreEventAllowSystem);). I thought this should do it, because the
drag handles div and the contents div are over the controls div, so the
mouseevents shouldn't reach the map and all will be like before, as a
workaround till I include the new buttonclick feature properly. But I
was wrong.
This works against passing the events through the control to the map.
But it collides with the dragging of the control. Because then the drag
starts also when clicking not only mousedown and doesn't stop until I
click outside the control which is only possible outside of the map(the
controls follows the mouse).
Also assigning olButton class to the drag handle doesn't work, with or
without the stopping of the events. Without stopping the events the
handle behaves strange, sometimes it is in drag mode after a click,
sometimes a click works and control minmizes or maximizes but on
mousedown the map is dragging with the control, cause the events not
stopped. If the behaviour would be predictable like "click on the handle
to start drag an click again to stop" it would be fine.
I hope someone can give me a hint or some new ideas.
And now some further questions.
What's the idea behind "buttonclick"? Prevent collision with handlers?
Will there also be a "mousemove" or a "mousebutton" event? Do we have to
assign all our buttons an olButton css-class?
Regards
Slawomir
Slawomir Messner
Forschungszentrum "Deutscher Sprachatlas"
