[OpenLayers-Users] Re: How it works WMSGetFeatureInfo??
Francesc Cañas kikocanas at gmail.com
Tue Feb 7 11:41:29 EST 2012
Yes indeed, the root response is good, if I open the request in a new
windows it displays the layer info.I'll try what you say and I'll tell you.
Thanks a lot!
2012/2/7 Max Stephan [via OSGeo.org] <ml-node+s1560n4372878h18 at n6.nabble.com
> Hi Francesc,
> for debugging the error you get in Firebug I would recommend to use the
> non-compressed OpenLayer-JS-files instead of the compressed ones - just
> import the OpenLayer.js from the lib folder instead of that from the
> "root"-folder and it will automatically import the single files. Anyway the
> error doesn´t result from the WMSGetFeatureInfo-request itself but from the
> popup-creation.
> But apart from that error. Could you have a look into Firebug to see if
> you even get a response from the server to your GetFeatureInfo-request? A
> very common error is that the request is not possible due to the
> restrictions of Javascript-cross-domain-policy (which means
> XML-HTTP-requests are only allowed when the client-HTML-page and the server
> - GeoServer in this case - are in the same domain). If your client and
> server should be in a different domain you would need to implement a proxy
> to your server.
> Best regards
> Max Stephan
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/How-it-works-WMSGetFeatureInfo-tp4361191p4372878.html
>  To unsubscribe from How it works WMSGetFeatureInfo??, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4361191&code=a2lrb2NhbmFzQGdtYWlsLmNvbXw0MzYxMTkxfC0xMDU3ODIxNDYx>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
http://kikocanas.blogspot.com
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-it-works-WMSGetFeatureInfo-tp4361191p4373142.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120207/0290fe27/attachment.html
