[OpenLayers-Users] edge panning
Alexandre Dube adube at mapgears.com
Fri Feb 17 12:34:41 EST 2012
Hi Rich,
   "With any drawing control active, paning the map can still be
achieved. Drag the map as usual for that." as mentioned and demonstrated
in this [example].  It is a default behavior now.  Could that do the
trick for you ?
Regards,
Alexandre
[example] http://openlayers.org/dev/examples/draw-feature.html
On 12-02-17 12:11 PM, Richard Greenwood wrote:
> I think this has come up a couple times but I don't know if anyone has
> implemented it yet. I'd like develop a feature that would
> automatically pan the map a fixed amount when the user is drawing and
> "bumps" up against an edge of the map window. Has anyone already done
> this? Is anyone interested in working with me on it? I'm thinking of a
> method that would monitor mouse moves and when the mouse reached the
> top, bottom, left or right pixel of the map window it would pan the
> map south, north, east or west, respectively, by ~20%. This would
> allow the use to draw features, or measure, beyond the extent of the
> map that was initially visible when they started.
> Best regards,
> Rich
Alexandre Dubé
Mapgears
www.mapgears.com
