[OpenLayers-Users] A LOT of features
Greg Allensworth gregor at greeninfo.org
Wed Jan 18 20:16:08 EST 2012
Well explained, Armin.
Short version: it's not the features, but the vertices.
A significant factor there is the parsing of the vertices: GML/XML is
significantly more "expensive" than JSON. If you're able to control the
format of the data you're loading, try making a JSON representation of
the data and including fewer attributes; this means less processing time
figuring out the data, which may help raise your ceiling.
If you have control over the dataset you're trying to render, you can
try a "simplify" on the data (this isn't an OpenLayers thing, it means
fudging your data server-side). This removes vertices and accuracy, in
exchange for raising the ceiling further. This can get dicey, though: it
would be wholly unsuitable for surveying applications, but may work fine
for indicating general areas such as state boundaries at large scales.
Greg Allensworth, Web GIS Developer
BS  A+  Network+  Security+  Linux+  Server+
GreenInfo Network - Information and Mapping in the Public Interest
564 Market Street, Suite 510  San Francisco CA 94104
PH: 415-979-0343 x302  FX: 415-979-0371    email: gregor at greeninfo.org
Web: www.GreenInfo.org     www.MapsPortal.org
Subscribe to MapLines, our e-newsletter, at www.GreenInfo.org
