[OpenLayers-Users] Adding multiple Image Layers
Andreas Hocevar
ahocevar at opengeo.org
Mon Jul 2 02:53:09 PDT 2012
instead of configuring the resolutions and the maxResolution on your
image layers, you could just configure
alwaysInRange: true
Maybe this fixes your issue.
Andreas.
On Mon, Jul 2, 2012 at 9:22 AM, Bennos <benjaminpreisig at gmx.at> wrote:
> Hi Andreas,
> As you can see in my sample code I am only using API options to configure my
> image layer, as well as the size constructor:
>> var theme = new OpenLayers.Layer.Image(
>> "Data", //name
>> "data/prec1h/GOOGLE.RR_15min.20120612.1215.15.png", //url
>> boundaries.transform(geographical,spherical), //extent
>> new OpenLayers.Size(598, 378), //size
>> { //options
>> isBaseLayer: false,
>> resolutions:map.layers[0].resolutions,
>> maxResolution : map.layers[0].resolutions[0],
>> aspectRatio: 0.9024712214132586
>> // visibility: false
>> map.addLayer(theme);
> When turning of the "resolution" and the "maxResolution" the image is not
> shown. The "aspectRatio" is not necesarry, I added it for testing purposes.
> Do you have any other idea, what could be wrong with my code?
> Regards,
> Benjamin
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Adding-multiple-Image-Layers-tp4984653p4985233.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
