[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Gery . gamejihou at hotmail.com
Thu Jul 5 10:05:02 PDT 2012
Hello Pedro,
uhmm one question, where did you put your html file? I work in rhel and my directories are in /var/www/html/
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> Date: Thu, 5 Jul 2012 16:28:04 +0100
> From: pedrocostaarma at sapo.pt
> To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> Thanks for helping me.
> I move my html files to a ubuntu server for testing and now i can't put
> proxy to work...
> Apache give me this error:
> (13)Permission denied: exec of
> '/var/www/pmapper-4.2.0/cgi-bin/proxy.py' failed
>   Premature end of script headers: proxy.py
> Does anybody know the cause?
> Thanks
> Em 04-07-2012 18:30, Gery . escreveu:
> It seems that firefox should be the problem, people tried the php code
> and that worked for them. The error in firebug gives you something else
> that may help to trace the source of error?
> si NO es necesario.
> Date: Wed, 4 Jul 2012 18:02:59 +0100
> From: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>
> To: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>;
> openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
> Thanks for your help Gery.
> I'm already tried with others browsers but the wfs doesn't show up.
> I had found some links that you tell me.
> I am tried a lot of alternatives  and I not discovered the problem.
> You think  the problem is firefox? If so why not appear in the IE wfs?
> I'm confused
> Em 04-07-2012 17:55, Gery . escreveu:
> This one may help you also, it worked for some people out there:
> http://www.webdeveloper.com/forum/showthread.php?t=187247
> Cheers,
> si NO es necesario.
> From: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>
> To: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>;
> Subject: RE: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> Date: Wed, 4 Jul 2012 16:52:22 +0000
> Hi Pedro,
> I was reading about this error in google and it seems that this is one
> of the solutions, you have to use this: var url = 'proxy_php.php?fn=' +
> encodeURIComponent(src);
> it seems that the problem is ajax (as far I understand), but it can be
> firefox, try first in IE or safari to see what happens. Also this page
> is suggested about the php code above:
> http://developer.yahoo.com/javascript/howto-proxy.html
> This page is in spanish, it may help you:
> http://www.forosdelweb.com/f127/ayuda-access-restricted-uri-denied-599455/
> Cheers,
> Gery
> si NO es necesario.
> Date: Wed, 4 Jul 2012 15:04:39 +0100
> Thank you Gery.
> Now my proxy is working but i got this error in firebug:
> 'Access to restricted URI denied'
> My code:
> http://pastebin.com/AGAFGSfn
> Em 04-07-2012 11:37, Gery . escreveu:
> Hi Pedro,
> Glad to hear that it was useful to you and it worked. Well, I think you
> better do what this console says, it is a very clever one =)
> If it says that it needs a proxy, it is very likely it needs one, just
> add the one you use, localhost:8080 or something like that, you can
> start playing with that and the FB console will tell you what to do
> after each step. Trust in this console, it's our friend =)
> Cheers,
> Gery
> si NO es necesario.
> Date: Wed, 4 Jul 2012 11:33:24 +0100
> Thanks Gery...
> I think that now i'm using ol firebug because i got alerts:
> proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
> This means i nedd proxy despite i'm using only local data?
> Thanks
> Em 04-07-2012 11:16, Gery . escreveu:
> Hola Pedro,
> I don't know if this helps, but you're using firebug as add-on of
> firefox or the one it comes with OpenLayers? I think you're using the
> first one. I've had better results (generally spoken) with the second
> one, just add the path of the javascript to your html <link>, I don't
> remember well the path but if I'm not wrong is
> /openlayers/lib/openlayers/Firebug.js, you can google it also. That js
> script is really useful, it tells in detail where the error is (ie.
> which js script and which line), at least in my case. Also, even though
> I don't work with geoserver or bing, I think you have to specify the
> projection in bing, but not sure. Sometimes I found that projection
> stuff is the one that *ucks everything.
> Hope this helps,
> Gery
> si NO es necesario.
> Date: Wed, 4 Jul 2012 11:06:36 +0100
> To: ramotswa at gmail.com<mailto:ramotswa at gmail.com>;
> Also no erros on console...
> Anybody have an ideia?
> all the code here:
> http://pastebin.com/mRnDC3UG
> Em 04-07-2012 10:58, Toby Reinicke escreveu:
> Umm, yes, theoretically, although I'm slightly confused why there is
> only one tab and hasn't got a response one. Your syntax looks fine,
> although others might be able to confirm that. As for proxy, as you say
> you should be fine, and if it wasn't you'd get some cross domain errors
> in your console..
> Sorry I can't help more.
> Toby
> On 4 Jul 2012, at 10:27, Pedro Costa
> <pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>> wrote:
> Hi Tobias,
> This(image attached)?
> Em 04-07-2012 10:21, Tobias Reinicke escreveu:
> If you expand that "options.wfs" in the firebug console, what does the
> "response" tab have in it?
> On 4 July 2012 10:09, Pedro Costa
> I forgot image....
> -------- Mensagem Original --------
> Assunto:        my vector data don't show up - wfs
> Data:   Wed, 04 Jul 2012 09:56:54 +0100
> De:     Pedro Costa <pedrocostaarma at sapo.pt><mailto:pedrocostaarma at sapo.pt>
> Para:
> Hi,
> I'm trying to add vector data to my map from geoserver but data don't
> show up.
> I tried like that:
> var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
>              strategies: [new OpenLayers.Strategy.BBOX()],
>              protocol: new OpenLayers.Protocol.WFS({
>              url: "http://localhost:8080/geoserver/testes/wfs"<http://localhost:8080/geoserver/testes/wfs>,
>              featurePrefix:"testes",
>              featureType: "testes:equipamentos",
>              featureNS: "namespacetestes.pt<http://namespacetestes.pt>",
>              srsName: "EPSG:900913",
>              geometryName: "the_geom",
>              version: "1.0.0"
> map.addLayer(wfs);
> I'm using only data from localhost (my computer) so i don't need proxy
> right?
> Using firebug I can see that the request is made, but returns nothing
> (image attached).
> Can anybody help me?
> Thanks
> Users mailing list
> Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> <request.png>
> _______________________________________________ Users mailing list
