[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Pedro Costa
pedrocostaarma at sapo.pt
Thu Jul 5 11:14:43 PDT 2012
Gery and others,
Thank you for your help. Now i can see WFS on html page (ubuntu)!!!!!!!!
I'm just add host 'mydomain:8080' to allowed host in proxy file, change
the path to python and put a missing '...
Thank you to all
Em 05-07-2012 18:05, Gery . escreveu:
> Hello Pedro,
> uhmm one question, where did you put your html file? I work in rhel and my directories are in /var/www/html/
> Cheers,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
>> Date: Thu, 5 Jul 2012 16:28:04 +0100
>> From: pedrocostaarma at sapo.pt
>> To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
>> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
>> Thanks for helping me.
>> I move my html files to a ubuntu server for testing and now i can't put
>> proxy to work...
>> Apache give me this error:
>> (13)Permission denied: exec of
>> '/var/www/pmapper-4.2.0/cgi-bin/proxy.py' failed
>> Premature end of script headers: proxy.py
>> Does anybody know the cause?
>> Thanks
>> Em 04-07-2012 18:30, Gery . escreveu:
>> It seems that firefox should be the problem, people tried the php code
>> and that worked for them. The error in firebug gives you something else
>> that may help to trace the source of error?
>> si NO es necesario.
>> Date: Wed, 4 Jul 2012 18:02:59 +0100
>> From: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>
>> To: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>;
>> openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
>> Thanks for your help Gery.
>> I'm already tried with others browsers but the wfs doesn't show up.
>> I had found some links that you tell me.
>> I am tried a lot of alternatives and I not discovered the problem.
>> You think the problem is firefox? If so why not appear in the IE wfs?
>> I'm confused
>> Em 04-07-2012 17:55, Gery . escreveu:
>> This one may help you also, it worked for some people out there:
>> http://www.webdeveloper.com/forum/showthread.php?t=187247
>> Cheers,
>> si NO es necesario.
>> From: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>
>> To: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>;
>> Subject: RE: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
>> Date: Wed, 4 Jul 2012 16:52:22 +0000
>> Hi Pedro,
>> I was reading about this error in google and it seems that this is one
>> of the solutions, you have to use this: var url = 'proxy_php.php?fn=' +
>> encodeURIComponent(src);
>> it seems that the problem is ajax (as far I understand), but it can be
>> firefox, try first in IE or safari to see what happens. Also this page
>> is suggested about the php code above:
>> http://developer.yahoo.com/javascript/howto-proxy.html
>> This page is in spanish, it may help you:
>> http://www.forosdelweb.com/f127/ayuda-access-restricted-uri-denied-599455/
>> Cheers,
>> Gery
>> si NO es necesario.
>> Date: Wed, 4 Jul 2012 15:04:39 +0100
>> Thank you Gery.
>> Now my proxy is working but i got this error in firebug:
>> 'Access to restricted URI denied'
>> My code:
>> http://pastebin.com/AGAFGSfn
>> Em 04-07-2012 11:37, Gery . escreveu:
>> Hi Pedro,
>> Glad to hear that it was useful to you and it worked. Well, I think you
>> better do what this console says, it is a very clever one =)
>> If it says that it needs a proxy, it is very likely it needs one, just
>> add the one you use, localhost:8080 or something like that, you can
>> start playing with that and the FB console will tell you what to do
>> after each step. Trust in this console, it's our friend =)
>> Cheers,
>> Gery
>> si NO es necesario.
>> Date: Wed, 4 Jul 2012 11:33:24 +0100
>> Thanks Gery...
>> I think that now i'm using ol firebug because i got alerts:
>> proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
>> This means i nedd proxy despite i'm using only local data?
>> Thanks
>> Em 04-07-2012 11:16, Gery . escreveu:
>> Hola Pedro,
>> I don't know if this helps, but you're using firebug as add-on of
>> firefox or the one it comes with OpenLayers? I think you're using the
>> first one. I've had better results (generally spoken) with the second
>> one, just add the path of the javascript to your html <link>, I don't
>> remember well the path but if I'm not wrong is
>> /openlayers/lib/openlayers/Firebug.js, you can google it also. That js
>> script is really useful, it tells in detail where the error is (ie.
>> which js script and which line), at least in my case. Also, even though
>> I don't work with geoserver or bing, I think you have to specify the
>> projection in bing, but not sure. Sometimes I found that projection
>> stuff is the one that *ucks everything.
>> Hope this helps,
>> Gery
>> si NO es necesario.
>> Date: Wed, 4 Jul 2012 11:06:36 +0100
>> To: ramotswa at gmail.com<mailto:ramotswa at gmail.com>;
>> Also no erros on console...
>> Anybody have an ideia?
>> all the code here:
>> http://pastebin.com/mRnDC3UG
>> Em 04-07-2012 10:58, Toby Reinicke escreveu:
>> Umm, yes, theoretically, although I'm slightly confused why there is
>> only one tab and hasn't got a response one. Your syntax looks fine,
>> although others might be able to confirm that. As for proxy, as you say
>> you should be fine, and if it wasn't you'd get some cross domain errors
>> in your console..
>> Sorry I can't help more.
>> Toby
>> On 4 Jul 2012, at 10:27, Pedro Costa
>> <pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>> wrote:
>> Hi Tobias,
>> This(image attached)?
>> Em 04-07-2012 10:21, Tobias Reinicke escreveu:
>> If you expand that "options.wfs" in the firebug console, what does the
>> "response" tab have in it?
>> On 4 July 2012 10:09, Pedro Costa
>> I forgot image....
>> -------- Mensagem Original --------
>> Assunto: my vector data don't show up - wfs
>> Data: Wed, 04 Jul 2012 09:56:54 +0100
>> De: Pedro Costa <pedrocostaarma at sapo.pt><mailto:pedrocostaarma at sapo.pt>
>> Para:
>> Hi,
>> I'm trying to add vector data to my map from geoserver but data don't
>> show up.
>> I tried like that:
>> var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
>> strategies: [new OpenLayers.Strategy.BBOX()],
>> protocol: new OpenLayers.Protocol.WFS({
>> url: "http://localhost:8080/geoserver/testes/wfs"<http://localhost:8080/geoserver/testes/wfs>,
>> featurePrefix:"testes",
>> featureType: "testes:equipamentos",
>> featureNS: "namespacetestes.pt<http://namespacetestes.pt>",
>> srsName: "EPSG:900913",
>> geometryName: "the_geom",
>> version: "1.0.0"
>> map.addLayer(wfs);
>> I'm using only data from localhost (my computer) so i don't need proxy
>> right?
>> Using firebug I can see that the request is made, but returns nothing
>> (image attached).
>> Can anybody help me?
>> Thanks
>> Users mailing list
>> Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> <request.png>
>> _______________________________________________ Users mailing list
