[OpenLayers-Users] Component returned failure code: 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]
Aaron E-J
azintirea at gmail.com
Wed Jul 11 12:45:31 PDT 2012
Spoke too soon again...
Aaron E-J
http://otherrealm.org
http://aaronej.blogspot.com
Vision without action is a daydream,
Action without vision is a nightmare,
One needs both to succeed.
On Wed, Jul 11, 2012 at 3:41 PM, Aaron E-J <azintirea at gmail.com> wrote:
> The OpenLayers.debug.js version seems to work for the 2.12 version, not
> sure what the issue is with the other versions.
> Aaron E-J
> On Wed, Jul 11, 2012 at 2:52 PM, Aaron E-J <azintirea at gmail.com> wrote:
>> Well, now it's happening using: http://openlayers.org/dev/OpenLayers.jsas well. Will try an earlier version and see if that fixes it
>> Aaron E-J
>> On Wed, Jul 11, 2012 at 12:28 PM, Aaron E-J <azintirea at gmail.com> wrote:
>>> This only seems to be for the local copy I have (lib/OpenLayers.js),
>>> using http://openlayers.org/dev/OpenLayers.js works find
>>> Aaron E-J
>>> On Wed, Jul 11, 2012 at 12:19 PM, Aaron E-J <azintirea at gmail.com> wrote:
>>>> I started getting a strange message on occasion (usually happens but
>>>> occasionally does not) that I'm not really sure how to fix it. There are
>>>> two forms of the same message in firebug, both seem to be about the same
>>>> thing:
>>>> Uncaught exception: [Exception... "Component returned failure code:
>>>> 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]"
>>>> nsresult: "0x8000ffff (NS_ERROR_UNEXPECTED)" location: "JS frame ::
>>>> http://localhost/phpEx/lib/OpenLayers/Renderer/SVG.js :: <TOP_LEVEL>
>>>> :: line 77" data: no]
>>>> error source line:
>>>> return (document.implementation &&
>>>> The function that this appears to be effecting:
>>>> * APIMethod: supported
>>>> * Returns:
>>>> * {Boolean} Whether or not the browser supports the SVG renderer
>>>> supported: function() {
>>>> var svgFeature = "http://www.w3.org/TR/SVG11/feature#";
>>>> (document.implementation.hasFeature("org.w3c.svg", "1.0") ||
>>>> document.implementation.hasFeature(svgFeature + "SVG",
>>>> "1.1") ||
>>>> "BasicStructure", "1.1") ));
>>>> I'm using the latest Firefox release (13.0.1) and it should handle SVG
>>>> no problem… My guess is this is a bug related to OpenLayers v2.12. Does
>>>> anyone know whether this is, in fact, a bug and whether it is being dealt
>>>> with? Thanks.
>>>> Aaron E-J
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120711/a32a8527/attachment-0001.html>
