[OpenLayers-Users] wfs-t Error performing insert
islanis at infomed.sld.cu islanis at infomed.sld.cu
Wed Jul 18 12:35:20 PDT 2012
hi am using wfs-t to save wfs in form of points to a bd but a load it
from the postgresql bd without problem , but i think that i use
geometry type in wrong way because the error but i dont know how to
fix it, help me please. thanks
//////////////////////error when i try to save captured with
firebug////////////
<ows:ExceptionReport version="1.0.0"
   xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows">
   <ows:Exception exceptionCode="InvalidParameterValue">
     <ows:ExceptionText>Error performing insert: java.lang.String
cannot be cast to
com.vividsolutions.jts.geom.Geometry</ows:ExceptionText>
   </ows:Exception>
</ows:ExceptionReport>
/////////modified data sent throug the post to the bd using wfs-t
captured with firebug///////////////////////////////
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Insert>
<feature:uneBiogas xmlns:feature="http://localhost:8080/geoserver/">
<feature:the_geom>
<gml:MultiPoint xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
<gml:pointMember>
<gml:Point>
<gml:pos>-82.794453125 21.721328125</gml:pos>
</gml:Point>
</gml:pointMember>
</gml:MultiPoint>
</feature:the_geom>
<feature:codigo>110</feature:codigo>
<feature:cpopular>sdfsdf</feature:cpopular>
<feature:empresa>gjhg</feature:empresa>
<feature:nombre></feature:nombre>
<feature:ubicacion>hgj</feature:ubicacion>
<feature:cantidad>5</feature:cantidad>
<feature:func>5</feature:func>
<feature:pdiaria></feature:pdiaria>
<feature:tbiomasa>bnvn</feature:tbiomasa>
<feature:uso>vnbv</feature:uso>
<feature:tbiodigest>bvn</feature:tbiodigest>
</feature:uneBiogas>
</wfs:Insert>
</wfs:Transaction>
///this is the format when i try to load the data from the bd and it
load it without problem///////
<wfs:FeatureCollection numberOfFeatures="24"
timeStamp="2012-07-18T20:45:50.328+02:00"
xsi:schemaLocation="http://localhost:8080/geoserver/
http://localhost:8080/geoserver/une/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=une%3AuneBiogas http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:une="http://localhost:8080/geoserver/" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ows="http://www.opengis.net/ows"
xmlns:wfs="http://www.opengis.net/wfs">
<gml:featureMembers>
<une:uneBiogas gml:id="uneBiogas.1">
<une:codigo>06</une:codigo>
<une:cpopular>06</une:cpopular>
<une:empresa>MINED</une:empresa>
<une:nombre>Univeersid</une:nombre>
<une:ubicacion>Biotecnologia</une:ubicacion>
<une:cantidad></une:cantidad>
<une:func>Si</une:func>
<une:pdiaria>1 m3</une:pdiaria>
<une:tbiomasa>Vacuno</une:tbiomasa>
<une:uso>Laboratori</une:uso>
<une:tbiodigest>Hindu</une:tbiodigest>
<une:the_geom>
<gml:Point srsDimension="2"
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:pos>-75.80539297751133 20.052260421762636</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.2">
<une:empresa>MICONS</une:empresa>
<une:nombre>EREA</une:nombre>
<une:ubicacion>Carretera</une:ubicacion>
<une:func>NO</une:func>
<une:pdiaria>6 m3</une:pdiaria>
<une:tbiomasa>Agua, Miel</une:tbiomasa>
<une:uso>Cocina</une:uso>
<une:the_geom>
<gml:pos>-75.78659055658719 20.0924152412809</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.3">
<une:nombre>Prefabrica</une:nombre>
<une:ubicacion>Micro 9 Distrito Jos</une:ubicacion>
<une:func>No</une:func>
<une:tbiomasa>Cachaza</une:tbiomasa>
<une:the_geom>
<gml:pos>-75.8235218220665 20.05657031527596</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.4">
<une:empresa>MINCIN</une:empresa>
<une:nombre>UBPC Chago</une:nombre>
<une:ubicacion>Carretera de las Laj</une:ubicacion>
<une:pdiaria>15 m3</une:pdiaria>
<une:tbiomasa>Porcino</une:tbiomasa>
<une:the_geom>
<gml:pos>-75.81299920619401 20.07856831778891</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.5">
<une:empresa>MININT</une:empresa>
<une:nombre>Prision de</une:nombre>
<une:ubicacion>Boniato</une:ubicacion>
<une:cantidad>2</une:cantidad>
<une:func>2</une:func>
<une:pdiaria>80 m3</une:pdiaria>
<une:uso>Cocina, La</une:uso>
<une:the_geom>
<gml:pos>-75.82493690254024 20.066733165427436</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.6">
<une:empresa>Poblaci?</une:empresa>
<une:nombre>Casa Ingen</une:nombre>
<une:ubicacion>II Crucero Boniato</une:ubicacion>
<une:cantidad>1</une:cantidad>
<une:func>1</une:func>
<une:pdiaria>2m3</une:pdiaria>
<une:the_geom>
<gml:pos>-75.80444015526064 20.083769458540683</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.7">
<une:nombre>Emp.Mat. d</une:nombre>
<une:ubicacion>Carretera del Caney</une:ubicacion>
<une:func>0</une:func>
<une:pdiaria></une:pdiaria>
<une:the_geom>
<gml:pos>-75.78321099719298 20.044772846911723</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.8">
<une:codigo>02</une:codigo>
<une:cpopular>02</une:cpopular>
<une:empresa>Casa Parti</une:empresa>
<une:nombre></une:nombre>
<une:ubicacion>Palmarito de Cauto</une:ubicacion>
<une:tbiomasa>Cachaza y estier</une:tbiomasa>
<une:uso>Cocina y f</une:uso>
<une:tbiodigest>Soterrado</une:tbiodigest>
<une:the_geom>
<gml:pos>-75.91214998813682 20.322742707187242</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.9">
<une:empresa>Particular</une:empresa>
<une:ubicacion>Mella</une:ubicacion>
<une:cantidad>5</une:cantidad>
<une:func>5</une:func>
<une:uso>Cocina y F</une:uso>
<une:the_geom>
<gml:pos>-75.90520617057932 20.369608293398926</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.10">
<une:ubicacion>San Francisco</une:ubicacion>
<une:tbiomasa>CAcahaza estier</une:tbiomasa>
<une:the_geom>
<gml:pos>-75.9106008715649 20.36810499514674</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.11">
<une:ubicacion>Baragua</une:ubicacion>
<une:tbiomasa>Cachaza y Estier</une:tbiomasa>
<une:the_geom>
<gml:pos>-75.96763120992536 20.470265323922828</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.12">
<une:empresa>FAR</une:empresa>
<une:ubicacion>UM Baragua</une:ubicacion>
<une:the_geom>
<gml:pos>-75.97431488402707 20.460520783098573</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.13">
<une:ubicacion>Estado Mayor</une:ubicacion>
<une:the_geom>
<gml:pos>-75.97745478389265 20.46596876981002</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.14">
<une:nombre>PNR</une:nombre>
<une:the_geom>
<gml:pos>-75.97142798860145 20.461321127008294</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.15">
<une:codigo>08</une:codigo>
<une:cpopular>08</une:cpopular>
<une:empresa></une:empresa>
<une:ubicacion>La Lata</une:ubicacion>
<une:the_geom>
<gml:pos>-76.24508638255578 20.103084457908366</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.16">
<une:empresa>Empresa Pe</une:empresa>
<une:ubicacion></une:ubicacion>
<une:cantidad>3</une:cantidad>
<une:uso>Alumbrado</une:uso>
<une:the_geom>
<gml:pos>-76.25757323944333 20.15332658172503</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.17">
<une:codigo>04</une:codigo>
<une:cpopular>04</une:cpopular>
<une:empresa>Matadero</une:empresa>
<une:ubicacion>Matadero Micara</une:ubicacion>
<une:the_geom>
<gml:pos>-75.55467939930811 20.42968760049703</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.18">
<une:ubicacion>Pueblo nuevo</une:ubicacion>
<une:pdiaria>2 m3</une:pdiaria>
<une:the_geom>
<gml:pos>-75.53120216452062 20.417680516486257</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.19">
<une:codigo></une:codigo>
<une:cpopular></une:cpopular>
<une:func></une:func>
<une:tbiomasa></une:tbiomasa>
<une:uso></une:uso>
<une:tbiodigest></une:tbiodigest>
<une:the_geom>
<gml:pos>-75.43885118724081 20.411219603511014</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.20">
<une:codigo>05</une:codigo>
<une:cpopular>05</une:cpopular>
<une:empresa>MINAGRI</une:empresa>
<une:ubicacion>CCS jesus Menedez</une:ubicacion>
<une:pdiaria>7m3</une:pdiaria>
<une:the_geom>
<gml:pos>-75.70602340669974 20.175134496925793</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.21">
<une:empresa>Mielera</une:empresa>
<une:ubicacion>Los Reinaldos</une:ubicacion>
<une:the_geom>
<gml:pos>-75.49184182915633 20.179687807052918</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.22">
<une:codigo>07</une:codigo>
<une:nombre>Politecnic</une:nombre>
<une:ubicacion>Politecnico</une:ubicacion>
<une:uso></une:uso>
<une:the_geom>
<gml:pos>-76.00645557483936 20.25001951404522</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.23">
<une:cantidad>17</une:cantidad>
<une:func>7</une:func>
<une:uso></une:uso>
<une:the_geom>
<gml:pos>-76.01135996037861 20.24433051096415</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
<une:uneBiogas gml:id="uneBiogas.24">
<une:cpopular>Pal</une:cpopular>
<une:tbiomasa>Cacahaza estier</une:tbiomasa>
<une:the_geom>
<gml:pos>-76.04120916128417 20.371856158704052</gml:pos>
</gml:Point>
</une:the_geom>
</une:uneBiogas>
</gml:featureMembers>
</wfs:FeatureCollection>
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
