[OpenLayers-Users] wfs-t Error performing insert
islanis at infomed.sld.cu islanis at infomed.sld.cu
Wed Jul 18 12:52:32 PDT 2012
i forgot put my code is this
<script type="text/javascript">
var map;
OpenLayers.ProxyHost = "http://localhost/cgi-bin/proxy.cgi?url=";
  Ext.BLANK_IMAGE_URL = "ext-3.4.0/resources/images/default/s.gif";
/////////////////////////mapa////////////////////////////////////////////
//////////////////////////Variables///////////////////////////////////////////////
var vlayer;
var controls = [];
var popupInfo;
var bounds = new OpenLayers.Bounds
		-84.956, 19.825,
		-74.132, 23.984
vlayer = new OpenLayers.Layer.Vector("Puntos de Biogas seleccionados");
var modifyControl = new OpenLayers.Control.ModifyFeature(
		vlayer, {autoActivate: true}
var drawControl = new OpenLayers.Control.DrawFeature(
		vlayer,
		OpenLayers.Handler.Polygon,
		{handlerOptions: {multi: true}}
	controls = [//new OpenLayers.Control.PanZoomBar(),
				//new OpenLayers.Control.Permalink(),
				new OpenLayers.Control.Navigation(),
				//new OpenLayers.Control.EditingToolbar(vlayer),
				//new OpenLayers.Control.PanZoom(),
				//new OpenLayers.Control.NavToolbar(),
     			//new OpenLayers.Control.LayerSwitcher(),
				new OpenLayers.Control.Attribution(),
				new OpenLayers.Control.ScaleLine(),
				new OpenLayers.Control.OverviewMap(),
				//new OpenLayers.Control.WMSGetFeatureInfo(),
				new OpenLayers.Control.MousePosition(),
				// new OpenLayers.Control.MouseToolbar(),
				modifyControl,
				drawControl
	var options = {
                 controls: controls,
                 maxExtent: bounds,
                 maxResolution: 0.02528125,
                 projection: "EPSG:4326",
                 units: 'degrees'
     map = new OpenLayers.Map('map',options);
	var nav = new OpenLayers.Control.NavigationHistory();
	map.addControl(new OpenLayers.Control.LayerSwitcher());
     map.addControl(nav);
	nav.activate();
	var panel = new OpenLayers.Control.Panel({div:
document.getElementById("panel")});
     panel.addControls([nav.next, nav.previous]);
     map.addControl(panel);
	var base = new OpenLayers.Layer.WMS(
                     "Mapa base de cuba",
"http://localhost:8080/geoserver/wms",
                         LAYERS: 'Base_General',
                         STYLES: '',
                         format: 'image/png',
                         tiled: true,
                         tilesOrigin : map.maxExtent.left + ',' +
map.maxExtent.bottom
                         buffer: 0,
                         displayOutsideMaxExtent: true,
                         isBaseLayer: true
	var inventario = new OpenLayers.Layer.WMS(
												"Puntos de Biogas disponibles",
												"http://localhost:8080/geoserver/une/wms",
												{'layers': 'une:uneBiogas',transparent: true, format:
'image/gif'},
												{isBaseLayer: false}//,
												//{opacity : 0.9}
     map.addLayers([base,inventario,vlayer]);
	/*control = new OpenLayers.Control.GetFeature({
					protocol: OpenLayers.Protocol.WFS.fromWMSLayer(inventario)//,
					//box: true,
					//hover: true,
					//multipleKey: "shiftKey",
					//toggleKey: "ctrlKey"
	/*control.events.register("featureselected", this, function(e) {
					vlayer.addFeatures([e.feature]);
					//featureGrid.collapse(true);
					alert("yes");
					//popupBiogas(e);
     /*control.events.register("featureunselected", this, function(e) {
					vlayer.removeFeatures([e.feature]);
	//control.events.register("click", this, popupBiogas);
	//map.events.register('click',map,popupBiogas);
	map.addControl(control);
	control.activate();*/
	map.zoomToMaxExtent();
//    map.zoomToMaxExtent();
</script>
src="http://localhost:8080/geoserver/pdf/info.json?var=printCapabilities"></script>
var mapPanel,printProvider,comentario,items = [];
printProvider = new GeoExt.data.PrintProvider({
     method: "GET", // "POST" recommended for production use
     capabilities: printCapabilities,	// from the info.json script in the html
	customParams: {
             mapTitle: "Biomasa Biogás",
             comment: "Estudios de SIGFRE"//comentario
var printExtent = new GeoExt.plugins.PrintExtent({
         printProvider: printProvider
////////////////////funcion
principal///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
var toolbarItems =[], checkImprimir, btnImprimir,comentImprimir,labelImpri;
labelImpri=new Ext.form.Label({text:"Comentario",hidden: true});
comentImprimir= new Ext.form.TextArea({
										hidden: true,
										overflow:'auto',
										label: 'Comentario',
										preventScrollbars:true,
										autoScroll: true,
										height: "60",width:"70"
btnImprimir = new Ext.Button({
         text: "Imprimir",
         handler: function(){
			comentario=comentImprimir.text;
             mapPanel.plugins[0].print();
checkImprimir = {
		text: 'Imprimir...',
         enableToggle: true,
         toggleHandler: onItemToggle,
         pressed: false,
		icon: 'assets/ge/img/printer.png'
function onItemToggle(pressed){
							if(this.pressed==true)
								mapPanel.plugins[0].show();
								btnImprimir.show();
								//comentImprimir.show();
								//labelImpri.show();
								else
								mapPanel.plugins[0].hide();
								btnImprimir.hide();
								//comentImprimir.hide();
								//labelImpri.hide();
toolbarItems.push(checkImprimir);
toolbarItems.push(' ');
//toolbarItems.push(labelImpri);
//toolbarItems.push(comentImprimir);
toolbarItems.push(btnImprimir);
mapPanel = new GeoExt.MapPanel({
	region: "center",
	map:map,
	zoom: 0.8,
	plugins: [printExtent],
	tbar:toolbarItems
	//tbar:items
printExtent.addPage();
printExtent.pages[0].fit(mapPanel, false);
printExtent.hide();
btnImprimir.hide();
var legendPanel = new GeoExt.LegendPanel({
	collapsible:'true',
	animCollapse: true,
	collapsed: true,
     region: "east",
     width: 130,
     bodyStyle: "padding:5px",
     layerStore: mapPanel.layers
	var includeLegend;
items.push(mapPanel);
items.push(legendPanel);
var tree=new Ext.tree.TreePanel({
	ref: "tree",
	region: "west",
	collapsible:'true',
	animCollapse: true,
	collapsed: true,
	width: 200,
	autoScroll: true,
	enableDD: true,
	root: new GeoExt.tree.LayerContainer({
		expanded: true
	bbar: [{
		text: "Remove from Map",
		handler: function() {
			var node = app.tree.getSelectionModel().getSelectedNode();
			if (node && node.layer instanceof OpenLayers.Layer.WMS) {
				app.mapPanel.map.removeLayer(node.layer);
items.push(tree);
/*var featureGrid = new Ext.grid.GridPanel({
	ref: "featureGrid",
	collapsible:'true',
	animCollapse: true,
	collapsed: true,
	title: "Feature Table",
	region: "south",
	height: 150,
	sm: new GeoExt.grid.FeatureSelectionModel(),
	store: new Ext.data.Store(),
	columns: []
var featureGrid = new Ext.grid.EditorGridPanel({
	ref: "featureGrid",
	collapsible:'true',
	animCollapse: true,
	collapsed: true,
	region: "south",
	height: 150,
	columns: [],
	sm: new GeoExt.grid.FeatureSelectionModel({
		selectControl: modifyControl.selectControl,
		autoActivateControl: false,
		singleSelect: true
	bbar:[
	{text: "Eliminar",
			featureGrid.getSelectionModel().each(function(rec) {
				var feature = rec.getFeature();
				modifyControl.unselectFeature(feature);
				vlayer.removeFeatures([feature]);
				if (feature.state !== OpenLayers.State.INSERT) {
					feature.state = OpenLayers.State.DELETE;
					featureGrid.store.featureFilter = new OpenLayers.Filter({
						evaluate: function(f) { return feature !== f; }
					vlayer.addFeatures([feature]);
	new GeoExt.Action({
		control: drawControl,
		text: "Crear",
		enableToggle: true,
		ref:'crear'
	{text: "Guardar cambios",
			featureGrid.store.proxy.protocol.commit(
					vlayer.features, {
							callback: function() {
								selectedLayer.redraw(true);
								featureGrid.store.reload();
items.push(featureGrid);
///////////////sobreescribir el metodo read() de
OpenLayers.Format.WFSDescribeFeatureType///////////////
var read = OpenLayers.Format.WFSDescribeFeatureType.prototype.read;
OpenLayers.Format.WFSDescribeFeatureType.prototype.read = function() {
	rawAttributeData = read.apply(this, arguments);
	return rawAttributeData;
var rawAttributeData, selectedLayer;
function setLayerInGrid(layerr) {
		if(!(layerr instanceof OpenLayers.Layer.WMS)) {
			return;
	selectedLayer = null;
	vlayer.removeAllFeatures();
	featureGrid.reconfigure(
		new Ext.grid.ColumnModel([])
	var layer = layerr;
	var url = layerr.url.split("?")[0];
	var schema = new GeoExt.data.AttributeStore({
		url: url,
		baseParams: {
				"SERVICE": "WFS",
				"REQUEST": "DescribeFeatureType",
				"VERSION": "1.1.0",
				"TYPENAME": layer.params.LAYERS
		autoLoad: true,
		listeners: {
				"load": function(store) {
					featureGrid.setTitle(layer.name);
					selectedLayer = layer;
					configureGrid(store, url);
	vlayer.events.on({
		featureselected: function(e) {
		if(featureGrid.collapsed==true)
			if(popupInfo)
				popupInfo.close();
			popupInfo=createPopup(e);
		featureunselected:function(e) {
function createPopup(e) {
var itemspg = [];
Ext.each(e.feature, function(feature) {
	var pg = new Ext.grid.PropertyGrid({
					title: feature.fid,
					source: feature.attributes
	itemspg.push(pg);
popupInfo=new GeoExt.Popup({
			title: "Info del punto",
			ref:'popup',
			width: 200,
			height: 200,
			layout: "accordion",
			map: mapPanel,
			items: itemspg
		}).show();
function configureGrid(store, url) {
	var fields = [], columns = [], geometryName, geometryType;
	var geomRegex =
/gml:(Multi)?(Point|Line|Polygon|Surface|Geometry).*/;//Expresion
regular para determinar el tipo de geometria de la feature actual esto
se necesita para conocer si estamos tratando con un atributo de tipo
geometria o de tipo feature
	var types = {
		"xsd:int": "int",
		"xsd:short": "int",
		"xsd:long": "int",
		"xsd:string": "string",
		"xsd:dateTime": "string",
		"xsd:double": "float",
		"xsd:decimal": "float",
		"Line": "Path",
		"Surface": "Polygon"
store.each(function(rec) {
	var type = rec.get("type");
	var name = rec.get("name");
	var match = geomRegex.exec(type);
	if (match) {
		geometryName = name;
		geometryType = types[match[2]] || match[2];
		else
		fields.push({
		type: types[type]
		columns.push({
				xtype: types[type] == "string" ?
				"gridcolumn" :
				"numbercolumn",
				dataIndex: name,
				header: name,
				editor: {
					"textfield" :
					"numberfield"
featureGrid.reconfigure(new GeoExt.data.FeatureStore({
		autoLoad: true,
		proxy: new GeoExt.data.ProtocolProxy({
		protocol: new OpenLayers.Protocol.WFS({
			url: url,
			version: "1.1.0",
			featureType: rawAttributeData.featureTypes[0].typeName,
			featureNS: rawAttributeData.targetNamespace,
			srsName: "EPSG:4326",
			geometryName: geometryName,
			maxFeatures: 250,
		fields: fields
	new Ext.grid.ColumnModel(columns));
	featureGrid.store.bind(vlayer);
	featureGrid.getSelectionModel().bind(vlayer);
	drawControl.handler = new OpenLayers.Handler[geometryType](
			drawControl, drawControl.callbacks, drawControl.handlerOptions
function prueba(){
	legendPanel.collapse(true);
//tree.getSelectionModel().on("selectionchange", setLayer);
setLayerInGrid(inventario);
   new Ext.Container({
	renderTo: "content",
         layout: "border",
         width: '99%',
         height: 500,
         items: items
</script>
islanis at infomed.sld.cu escribió:
> hi am using wfs-t to save wfs in form of points to a bd but a load
> it from the postgresql bd without problem , but i think that i use
> geometry type in wrong way because the error but i dont know how to
> fix it, help me please. thanks
> //////////////////////error when i try to save captured with
> firebug////////////
> <?xml version="1.0" encoding="UTF-8"?>
> <ows:ExceptionReport version="1.0.0"
>   xsi:schemaLocation="http://www.opengis.net/ows
> http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
>   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ows="http://www.opengis.net/ows">
>   <ows:Exception exceptionCode="InvalidParameterValue">
>     <ows:ExceptionText>Error performing insert: java.lang.String
> cannot be cast to
> com.vividsolutions.jts.geom.Geometry</ows:ExceptionText>
>   </ows:Exception>
> </ows:ExceptionReport>
> /////////modified data sent throug the post to the bd using wfs-t
> captured with firebug///////////////////////////////
> <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs"
> service="WFS" version="1.1.0"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Insert>
> <feature:uneBiogas xmlns:feature="http://localhost:8080/geoserver/">
> <feature:the_geom>
> <gml:MultiPoint xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">
> <gml:pointMember>
> <gml:Point>
> <gml:pos>-82.794453125 21.721328125</gml:pos>
> </gml:Point>
> </gml:pointMember>
> </gml:MultiPoint>
> </feature:the_geom>
> <feature:codigo>110</feature:codigo>
> <feature:cpopular>sdfsdf</feature:cpopular>
> <feature:empresa>gjhg</feature:empresa>
> <feature:nombre></feature:nombre>
> <feature:ubicacion>hgj</feature:ubicacion>
> <feature:cantidad>5</feature:cantidad>
> <feature:func>5</feature:func>
> <feature:pdiaria></feature:pdiaria>
> <feature:tbiomasa>bnvn</feature:tbiomasa>
> <feature:uso>vnbv</feature:uso>
> <feature:tbiodigest>bvn</feature:tbiodigest>
> </feature:uneBiogas>
> </wfs:Insert>
> </wfs:Transaction>
> ///this is the format when i try to load the data from the bd and it
> load it without problem///////
> <wfs:FeatureCollection numberOfFeatures="24"
> timeStamp="2012-07-18T20:45:50.328+02:00"
> xsi:schemaLocation="http://localhost:8080/geoserver/
> http://localhost:8080/geoserver/une/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=une%3AuneBiogas http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:une="http://localhost:8080/geoserver/" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ows="http://www.opengis.net/ows"
> xmlns:wfs="http://www.opengis.net/wfs">
> <gml:featureMembers>
> <une:uneBiogas gml:id="uneBiogas.1">
> <une:codigo>06</une:codigo>
> <une:cpopular>06</une:cpopular>
> <une:empresa>MINED</une:empresa>
> <une:nombre>Univeersid</une:nombre>
> <une:ubicacion>Biotecnologia</une:ubicacion>
> <une:cantidad></une:cantidad>
> <une:func>Si</une:func>
> <une:pdiaria>1 m3</une:pdiaria>
> <une:tbiomasa>Vacuno</une:tbiomasa>
> <une:uso>Laboratori</une:uso>
> <une:tbiodigest>Hindu</une:tbiodigest>
> <une:the_geom>
> <gml:Point srsDimension="2"
> srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
> <gml:pos>-75.80539297751133 20.052260421762636</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.2">
> <une:empresa>MICONS</une:empresa>
> <une:nombre>EREA</une:nombre>
> <une:ubicacion>Carretera</une:ubicacion>
> <une:func>NO</une:func>
> <une:pdiaria>6 m3</une:pdiaria>
> <une:tbiomasa>Agua, Miel</une:tbiomasa>
> <une:uso>Cocina</une:uso>
> <une:the_geom>
> <gml:pos>-75.78659055658719 20.0924152412809</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.3">
> <une:nombre>Prefabrica</une:nombre>
> <une:ubicacion>Micro 9 Distrito Jos</une:ubicacion>
> <une:func>No</une:func>
> <une:tbiomasa>Cachaza</une:tbiomasa>
> <une:the_geom>
> <gml:pos>-75.8235218220665 20.05657031527596</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.4">
> <une:empresa>MINCIN</une:empresa>
> <une:nombre>UBPC Chago</une:nombre>
> <une:ubicacion>Carretera de las Laj</une:ubicacion>
> <une:pdiaria>15 m3</une:pdiaria>
> <une:tbiomasa>Porcino</une:tbiomasa>
> <une:the_geom>
> <gml:pos>-75.81299920619401 20.07856831778891</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.5">
> <une:empresa>MININT</une:empresa>
> <une:nombre>Prision de</une:nombre>
> <une:ubicacion>Boniato</une:ubicacion>
> <une:cantidad>2</une:cantidad>
> <une:func>2</une:func>
> <une:pdiaria>80 m3</une:pdiaria>
> <une:uso>Cocina, La</une:uso>
> <une:the_geom>
> <gml:pos>-75.82493690254024 20.066733165427436</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.6">
> <une:empresa>Poblaci?</une:empresa>
> <une:nombre>Casa Ingen</une:nombre>
> <une:ubicacion>II Crucero Boniato</une:ubicacion>
> <une:cantidad>1</une:cantidad>
> <une:func>1</une:func>
> <une:pdiaria>2m3</une:pdiaria>
> <une:the_geom>
> <gml:pos>-75.80444015526064 20.083769458540683</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.7">
> <une:nombre>Emp.Mat. d</une:nombre>
> <une:ubicacion>Carretera del Caney</une:ubicacion>
> <une:func>0</une:func>
> <une:pdiaria></une:pdiaria>
> <une:the_geom>
> <gml:pos>-75.78321099719298 20.044772846911723</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.8">
> <une:codigo>02</une:codigo>
> <une:cpopular>02</une:cpopular>
> <une:empresa>Casa Parti</une:empresa>
> <une:nombre></une:nombre>
> <une:ubicacion>Palmarito de Cauto</une:ubicacion>
> <une:tbiomasa>Cachaza y estier</une:tbiomasa>
> <une:uso>Cocina y f</une:uso>
> <une:tbiodigest>Soterrado</une:tbiodigest>
> <une:the_geom>
> <gml:pos>-75.91214998813682 20.322742707187242</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.9">
> <une:empresa>Particular</une:empresa>
> <une:ubicacion>Mella</une:ubicacion>
> <une:cantidad>5</une:cantidad>
> <une:func>5</une:func>
> <une:uso>Cocina y F</une:uso>
> <une:the_geom>
> <gml:pos>-75.90520617057932 20.369608293398926</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.10">
> <une:ubicacion>San Francisco</une:ubicacion>
> <une:tbiomasa>CAcahaza estier</une:tbiomasa>
> <une:the_geom>
> <gml:pos>-75.9106008715649 20.36810499514674</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.11">
> <une:ubicacion>Baragua</une:ubicacion>
> <une:tbiomasa>Cachaza y Estier</une:tbiomasa>
> <une:the_geom>
> <gml:pos>-75.96763120992536 20.470265323922828</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.12">
> <une:empresa>FAR</une:empresa>
> <une:ubicacion>UM Baragua</une:ubicacion>
> <une:the_geom>
> <gml:pos>-75.97431488402707 20.460520783098573</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.13">
> <une:ubicacion>Estado Mayor</une:ubicacion>
> <une:the_geom>
> <gml:pos>-75.97745478389265 20.46596876981002</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.14">
> <une:nombre>PNR</une:nombre>
> <une:the_geom>
> <gml:pos>-75.97142798860145 20.461321127008294</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.15">
> <une:codigo>08</une:codigo>
> <une:cpopular>08</une:cpopular>
> <une:empresa></une:empresa>
> <une:ubicacion>La Lata</une:ubicacion>
> <une:the_geom>
> <gml:pos>-76.24508638255578 20.103084457908366</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.16">
> <une:empresa>Empresa Pe</une:empresa>
> <une:ubicacion></une:ubicacion>
> <une:cantidad>3</une:cantidad>
> <une:uso>Alumbrado</une:uso>
> <une:the_geom>
> <gml:pos>-76.25757323944333 20.15332658172503</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.17">
> <une:codigo>04</une:codigo>
> <une:cpopular>04</une:cpopular>
> <une:empresa>Matadero</une:empresa>
> <une:ubicacion>Matadero Micara</une:ubicacion>
> <une:the_geom>
> <gml:pos>-75.55467939930811 20.42968760049703</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.18">
> <une:ubicacion>Pueblo nuevo</une:ubicacion>
> <une:pdiaria>2 m3</une:pdiaria>
> <une:the_geom>
> <gml:pos>-75.53120216452062 20.417680516486257</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.19">
> <une:codigo></une:codigo>
> <une:cpopular></une:cpopular>
> <une:func></une:func>
> <une:tbiomasa></une:tbiomasa>
> <une:uso></une:uso>
> <une:tbiodigest></une:tbiodigest>
> <une:the_geom>
> <gml:pos>-75.43885118724081 20.411219603511014</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.20">
> <une:codigo>05</une:codigo>
> <une:cpopular>05</une:cpopular>
> <une:empresa>MINAGRI</une:empresa>
> <une:ubicacion>CCS jesus Menedez</une:ubicacion>
> <une:pdiaria>7m3</une:pdiaria>
> <une:the_geom>
> <gml:pos>-75.70602340669974 20.175134496925793</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.21">
> <une:empresa>Mielera</une:empresa>
> <une:ubicacion>Los Reinaldos</une:ubicacion>
> <une:the_geom>
> <gml:pos>-75.49184182915633 20.179687807052918</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.22">
> <une:codigo>07</une:codigo>
> <une:nombre>Politecnic</une:nombre>
> <une:ubicacion>Politecnico</une:ubicacion>
> <une:uso></une:uso>
> <une:the_geom>
> <gml:pos>-76.00645557483936 20.25001951404522</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.23">
> <une:cantidad>17</une:cantidad>
> <une:func>7</une:func>
> <une:uso></une:uso>
> <une:the_geom>
> <gml:pos>-76.01135996037861 20.24433051096415</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> <une:uneBiogas gml:id="uneBiogas.24">
> <une:cpopular>Pal</une:cpopular>
> <une:tbiomasa>Cacahaza estier</une:tbiomasa>
> <une:the_geom>
> <gml:pos>-76.04120916128417 20.371856158704052</gml:pos>
> </gml:Point>
> </une:the_geom>
> </une:uneBiogas>
> </gml:featureMembers>
> </wfs:FeatureCollection>
> This message was sent using IMP, the Internet Messaging Program.
> Este mensaje le ha llegado mediante el servicio de correo
> electronico que ofrece Infomed para respaldar el cumplimiento de las
> misiones del Sistema Nacional de Salud. La persona que envia este
> correo asume el compromiso de usar el servicio a tales fines y
> cumplir con las regulaciones establecidas
> Infomed: http://www.sld.cu/
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
