[OpenLayers-Users] OpenLayers.Control.SelectFeature
Riaan Lombaard rlombaard at maxgeo.com
Mon Jun 4 06:12:30 PDT 2012
Ah thanks,
Ok my select feature looks like this.
       //Create and add selectFeature control
       var select_feature_control = new OpenLayers.Control.SelectFeature(
              pointLayer,
                     multiple: false,
                     toggle: true,
                     toggleKey: 'ctrlKey',
                     multipleKey: 'shiftKey'
       var select_feature_control_ten = new OpenLayers.Control.SelectFeature(
              leaseLayer,
                     multiple: false,
                     toggle: true,
What you are saying is that I can combine these 2 in one?
From: Dominik Mikiewicz [mailto:dominikmikiewicz at o2.pl]
Sent: 04 June 2012 02:57 PM
To: Riaan Lombaard
Subject: RE: [OpenLayers-Users] OpenLayers.Control.SelectFeature
Your top select control 'covers' the other control.
You can use one select control for both layers.
From: openlayers-users-bounces at lists.osgeo.org<mailto:openlayers-users-bounces at lists.osgeo.org> [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Riaan Lombaard
Sent: Monday, June 04, 2012 2:36 PM
To: openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
Subject: [OpenLayers-Users] OpenLayers.Control.SelectFeature
Hey Guys,
Please assist.
I have 2 layers.
Layer 1. Vector Layer using only `OpenLayers.Geometry.Point` functionality.
Layer2. Vector Layer using only `OpenLayers.Geometry.LinearRing` functionality.
Now both of them have their own `OpenLayers.Control.SelectFeature` obviously adding, activating and registering the features on the map.
The issue I am having is, when both layers are active only one of the layers selection functionality will work.
For example if Layer1 and 2 are active, only Layer2 selection will work.
Only when I disable Layer2 then Layer1 selection will work.
Hope this make's sense. Please let me know if you need more information.
Riaan
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120604/b2e9078e/attachment.html>
