[OpenLayers-Users] Testing ol 2.12 rc6
Andreas Hocevar ahocevar at opengeo.org
Wed Jun 6 07:49:49 PDT 2012
We also need your map configuration.
Thanks,
Andreas.
On Wed, Jun 6, 2012 at 4:41 PM, Ricardo Bayley <ricardo.bayley at gmail.com> wrote:
> this is my GWC layer
> var lyr =  new OpenLayers.Layer.WMS(
> "street", ["http://myAddress:8080/geowebcache/service/wms"],
> layers: "Argentina",
> format: 'image/png'
> isBaseLayer: true,
> visibility: false,
> tileSize: new OpenLayers.Size(256,256),
> singleTile:false,
> tileLoadingDelay:0,
> buffer: 2,
> transitionEffect:'resize',
> minZoomLevel: 0,
> maxZoomLevel: 8
> * i change visibility later.
> var ghyb = new OpenLayers.Layer.Google(
>            "Híbrido",
>             type: G_HYBRID_MAP,
>             sphericalMercator: true, minZoomLevel: 4, maxZoomLevel: 18
> If I dont load google layers, problem does not go away.
> 2012/6/6 Andreas Hocevar <ahocevar at opengeo.org>
>> Code would be great. Especially showing your map and layer options.
>> Thanks,
>> Andreas.
>> On Wed, Jun 6, 2012 at 4:14 PM, Ricardo Bayley <ricardo.bayley at gmail.com>
>> wrote:
>> > Do you mean screenshot or live example or just code ?
>> > All I am doing is pointing to a different Openlayer js. So, yes with ol
>> > 2.11
>> > worked fine.
>> >> Hi,
>> >> Can you share a minimal example that shows the issue? Also, did this
>> >> work with OpenLayers 2.11?
>> >> Andreas.
>> >> On Wed, Jun 6, 2012 at 3:17 PM, Ricardo Bayley
>> >> wrote:
>> >> > Hi folks,
>> >> > I am testing ol 2.12 rc6 on my web app.
>> >> > I have a GWC wms layer, google hybrid + google sat.
>> >> > At start, GWC layer is not loading in the correct zoom layer. When
>> >> > zooming I
>> >> > get the blank image.
>> >> > When checking with GWC I get this message.
>> >> > 400: X,Y values for the tile index were calculated to be
>> >> > {81.13292818954577,
>> >> > 104.17067323102172} which had to be rounded to {81, 104} and exceeds
>> >> > the
>> >> > threshold of 10%. Perhaps the client is using the wrong origin ?
>> >> > My map is in south america, so both x and y should be negative,
>> >> > shouldnt
>> >> > they ?
>> >> > I think this maybe cause by the Projection & SphericalMercator
>> >> > changes.
>> >> > Is this so ?
>> >> > Thanks
>> >> > Ricardo
>> >> > _______________________________________________
>> >> > Users mailing list
>> >> > Users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> >> Andreas Hocevar
>> >> OpenGeo - http://opengeo.org/
>> >> Expert service straight from the developers.
>> Andreas Hocevar
Andreas Hocevar
