[OpenLayers-Users] Testing ol 2.12 rc6
Ricardo Bayley ricardo.bayley at gmail.com
Wed Jun 6 07:53:36 PDT 2012
I justtried this map config., and still not working.
var map = new OpenLayers.Map({
allOverlays: false,
theme: null,
scales
:[8735665,4367832,2183916,1091958,545979,272989,136494,68247,34123,17062,8531,4265],
projection: "EPSG:900913",
// displayProjection: "EPSG:4326",
// projection: new OpenLayers.Projection('EPSG:900913'),
// displayProjection: new OpenLayers.Projection('EPSG:4326'),
restrictedExtent:  new
OpenLayers.Bounds(-9500000.0,-8200000.0,-4500000.0,-1600000.0),
// maxExtent: new
OpenLayers.Bounds(-2.0E7,-2.0E7,2.0140799999999993E7,2.0140799999999993E7),
units: "m",
controls: [
           new OpenLayers.Control.Attribution(),
           new OpenLayers.Control.KeyboardDefaults(),
//           new OpenLayers.Control.LayerSwitcher({'ascending':true}),
           new OpenLayers.Control.Navigation({
       dragPanOptions:{enableKinetic: true,documentDrag: true},
       zoomWheelEnabled:true}
           new OpenLayers.Control.PanZoomBar({zoomWorldIcon:true})
2012/6/6 Andreas Hocevar <ahocevar at opengeo.org>
> We also need your map configuration.
> Thanks,
> Andreas.
> On Wed, Jun 6, 2012 at 4:41 PM, Ricardo Bayley <ricardo.bayley at gmail.com>
> wrote:
> > this is my GWC layer
> > var lyr =  new OpenLayers.Layer.WMS(
> > "street", ["http://myAddress:8080/geowebcache/service/wms"],
> > layers: "Argentina",
> > format: 'image/png'
> > isBaseLayer: true,
> > visibility: false,
> > tileSize: new OpenLayers.Size(256,256),
> > singleTile:false,
> > tileLoadingDelay:0,
> > buffer: 2,
> > transitionEffect:'resize',
> > minZoomLevel: 0,
> > maxZoomLevel: 8
> > * i change visibility later.
> > var ghyb = new OpenLayers.Layer.Google(
> >            "Híbrido",
> >             type: G_HYBRID_MAP,
> >             sphericalMercator: true, minZoomLevel: 4, maxZoomLevel: 18
> > If I dont load google layers, problem does not go away.
> >> Code would be great. Especially showing your map and layer options.
> >> Thanks,
> >> Andreas.
> >> On Wed, Jun 6, 2012 at 4:14 PM, Ricardo Bayley <
> >> wrote:
> >> > Do you mean screenshot or live example or just code ?
> >> > All I am doing is pointing to a different Openlayer js. So, yes with
> ol
> >> > 2.11
> >> > worked fine.
> >> >> Hi,
> >> >> Can you share a minimal example that shows the issue? Also, did this
> >> >> work with OpenLayers 2.11?
> >> >> Andreas.
> >> >> On Wed, Jun 6, 2012 at 3:17 PM, Ricardo Bayley
> >> >> wrote:
> >> >> > Hi folks,
> >> >> > I am testing ol 2.12 rc6 on my web app.
> >> >> > I have a GWC wms layer, google hybrid + google sat.
> >> >> > At start, GWC layer is not loading in the correct zoom layer. When
> >> >> > zooming I
> >> >> > get the blank image.
> >> >> > When checking with GWC I get this message.
> >> >> > 400: X,Y values for the tile index were calculated to be
> >> >> > {81.13292818954577,
> >> >> > 104.17067323102172} which had to be rounded to {81, 104} and
> exceeds
> >> >> > the
> >> >> > threshold of 10%. Perhaps the client is using the wrong origin ?
> >> >> > My map is in south america, so both x and y should be negative,
> >> >> > shouldnt
> >> >> > they ?
> >> >> > I think this maybe cause by the Projection & SphericalMercator
> >> >> > changes.
> >> >> > Is this so ?
> >> >> > Thanks
> >> >> > Ricardo
> >> >> > _______________________________________________
> >> >> > Users mailing list
> >> >> > Users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> >> >> Andreas Hocevar
> >> >> OpenGeo - http://opengeo.org/
> >> >> Expert service straight from the developers.
> >> Andreas Hocevar
> Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120606/ecac2653/attachment.html>
