[OpenLayers-Users] Testing ol 2.12 rc6
Andreas Hocevar ahocevar at opengeo.org
Wed Jun 6 08:25:19 PDT 2012
This is not a regression - your map configuration is incorrect. scales
is not an API property of the map. Move the scales definition to the
GWC layer, and you should be fine.
Andreas.
On Wed, Jun 6, 2012 at 4:49 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> We also need your map configuration.
> Thanks,
> Andreas.
> On Wed, Jun 6, 2012 at 4:41 PM, Ricardo Bayley <ricardo.bayley at gmail.com> wrote:
>> this is my GWC layer
>> var lyr =  new OpenLayers.Layer.WMS(
>> "street", ["http://myAddress:8080/geowebcache/service/wms"],
>> layers: "Argentina",
>> format: 'image/png'
>> isBaseLayer: true,
>> visibility: false,
>> tileSize: new OpenLayers.Size(256,256),
>> singleTile:false,
>> tileLoadingDelay:0,
>> buffer: 2,
>> transitionEffect:'resize',
>> minZoomLevel: 0,
>> maxZoomLevel: 8
>> * i change visibility later.
>> var ghyb = new OpenLayers.Layer.Google(
>>            "Híbrido",
>>             type: G_HYBRID_MAP,
>>             sphericalMercator: true, minZoomLevel: 4, maxZoomLevel: 18
>> If I dont load google layers, problem does not go away.
>> 2012/6/6 Andreas Hocevar <ahocevar at opengeo.org>
>>> Code would be great. Especially showing your map and layer options.
>>> Thanks,
>>> Andreas.
>>> On Wed, Jun 6, 2012 at 4:14 PM, Ricardo Bayley <ricardo.bayley at gmail.com>
>>> wrote:
>>> > Do you mean screenshot or live example or just code ?
>>> > All I am doing is pointing to a different Openlayer js. So, yes with ol
>>> > 2.11
>>> > worked fine.
>>> >> Hi,
>>> >> Can you share a minimal example that shows the issue? Also, did this
>>> >> work with OpenLayers 2.11?
>>> >> Andreas.
>>> >> On Wed, Jun 6, 2012 at 3:17 PM, Ricardo Bayley
>>> >> wrote:
>>> >> > Hi folks,
>>> >> > I am testing ol 2.12 rc6 on my web app.
>>> >> > I have a GWC wms layer, google hybrid + google sat.
>>> >> > At start, GWC layer is not loading in the correct zoom layer. When
>>> >> > zooming I
>>> >> > get the blank image.
>>> >> > When checking with GWC I get this message.
>>> >> > 400: X,Y values for the tile index were calculated to be
>>> >> > {81.13292818954577,
>>> >> > 104.17067323102172} which had to be rounded to {81, 104} and exceeds
>>> >> > the
>>> >> > threshold of 10%. Perhaps the client is using the wrong origin ?
>>> >> > My map is in south america, so both x and y should be negative,
>>> >> > shouldnt
>>> >> > they ?
>>> >> > I think this maybe cause by the Projection & SphericalMercator
>>> >> > changes.
>>> >> > Is this so ?
>>> >> > Thanks
>>> >> > Ricardo
>>> >> > _______________________________________________
>>> >> > Users mailing list
>>> >> > Users at lists.osgeo.org
>>> >> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> >> Andreas Hocevar
>>> >> OpenGeo - http://opengeo.org/
>>> >> Expert service straight from the developers.
>>> Andreas Hocevar
> Andreas Hocevar
Andreas Hocevar
