[OpenLayers-Users] light-basic popup
Tobias Reinicke ramotswa at gmail.com
Mon Jun 11 01:05:47 PDT 2012
Hi Smaran,
Ok. was hoping that that might have been the easy fix.
I looked at your JSFiddle url.  http://jsfiddle.net/qTFEa/4/
If you replace the OL url with the js from here
http://openlayers.org/api/2.12-rc6/OpenLayers.js
The pop up does seem to work. You aren't pulling in any vector layers
there, but I presume that is because of proxy / js fiddle issues.
Does that work for you? Is that not what you wanted?
Toby
On 8 June 2012 19:04, Smaran Harihar <smaran.harihar at gmail.com> wrote:
> Hi Tobias,
> I changed the code (it was a dumb mistake) but I am still not able to get
> the popup.
> Here is the JSFiddle <http://jsfiddle.net/smaran/qTFEa/2/> and my working
> application <http://niles.iplantcollaborative.org/demo/geo/test/map.html>.
> Thanks,
> Smaran
> On Fri, Jun 8, 2012 at 1:48 AM, Tobias Reinicke <ramotswa at gmail.com>wrote:
>> You have spelled "eventListeners" wrong...
>>> var vector = new OpenLayers.Layer.Vector("VecPopInfo",{
>>>  eventListners:{
>>> 'featureselected' :function(event) {
> Thanks & Regards
> Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120611/e832f1d7/attachment.html>
