[OpenLayers-Users] light-basic popup
aparna aparna.mookerjee at gmail.com
Mon Jun 11 02:26:14 PDT 2012
Smaran,
You have 6 layers on your map. The names are
0 bio11
1 Climate Data
2 All Quebec Species
3 Pima Pines
4 Carribean Pines
5 Editable Vectors
6 Select Features
If you could change your code a bit Popups from All Quebec Species layer
will take place on click event..
Here is some working code..
Add this code after you wms layers and replace with your own wfs layer names
etc.
var QS = new OpenLayers.Layer.Vector("Quebec", {
					strategies : [new OpenLayers.Strategy.Fixed()],
					projection : new OpenLayers.Projection("EPSG:4326"),
					visibility : true,
					protocol : new OpenLayers.Protocol.WFS({
						version : "1.1.0",
						url: "http://Aparna:8081/geoserver/wfs",
						//featurePrefix : 'iPlant', //geoserver worspace name
						featureType : "detail", //geoserver Layer Name
						featureNS: "http://opengeo.org/India" // Edit Workspace Namespace URI
map.addLayer(QS);
map.addControl(new OpenLayers.Control.LayerSwitcher());
        map.addControl(new OpenLayers.Control.MousePosition());
	map.zoomToMaxExtent();
var select= new OpenLayers.Control.SelectFeature(QS);
	QS.events.on({ "featureselected": onFeatureSelect, "featureunselected":
onFeatureUnselect});
		map.addControl(select);
		select.activate();
function onFeatureSelect(event) {
            var feature = event.feature;
            // Since KML is user-generated, do naive protection against
            // Javascript.
            //var X=feature.attributes.SCHCD;
            //var result=X.split
            var content = "<h7>Family: "+feature.attributes.FAMILY +"<br>"
+"</h7>" +"SPECIES: " +feature.attributes.SPECIES;
            if (content.search("<script") != -1) {
                content = "Content contained Javascript! Escaped
content below.<br>" + content.replace(/</g, "<");
            popup = new OpenLayers.Popup.FramedCloud("chicken",
            feature.geometry.getBounds().getCenterLonLat(),
            new OpenLayers.Size(100,100),content,
            null, true, onPopupClose);
            feature.popup = popup;
            map.addPopup(popup);
	 function onFeatureUnselect(event) {
            if(feature.popup) {
                map.removePopup(feature.popup);
                feature.popup.destroy();
                delete feature.popup;
	function onPopupClose(evt) {
            select.unselectAll();
Hope this works for you.
Regards,
Aparna
View this message in context: http://osgeo-org.1560.n6.nabble.com/light-basic-popup-tp4979830p4980346.html
