[OpenLayers-Users] pb with map.getZoom
Olivier Terral olivier at geomatic.ch
Tue Jun 19 07:52:15 PDT 2012
Hi Christian,
You're doing a getZoom() just after created the map and before a zooming function, so the zoom property of the map is logically 0.
Anyway, I think you use a wrong way of managing scale dependent size.
Your problem seems similar to this example: http://dev.openlayers.org/releases/OpenLayers-2.11/examples/label-scale.html .
Hope this helps.
Tschuuss
Le 19 juin 2012 à 15:05, christian bleau a écrit :
> Hi, i'm just trying to use OL and I meet a problem with map.getZoom here's url of my test. for adapt an size of an OpenLayers.Layer.Vector and an externalGraphic I call a var zoom with map.getZoom line: 159 I call var z= map.getZoom(); for change the size of an image But they don't work "Error: Invalid value for  attribute height="Infinity" If I try to see the z'value Firebug give me "0" .....   Thank a lot if you have the solution I search it since two days.
> View this message in context: pb with map.getZoom
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Olivier Terral
GEOMATIC Ingénierie SA
Société du groupe Ringier
Chemin des Croisettes 26
1066 Epalinges
www.geomatic.ch
www.thevirtualcity.ch
Tél:: +41 (21) 651 30 00
Fax: +41 (21) 651 30 09
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120619/c3980a72/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120619/c3980a72/attachment-0001.gif>
