[OpenLayers-Users] pb with map.getZoom
christian bleau christian.bleau at gmail.com
Wed Jun 20 06:01:37 PDT 2012
Hi Olivier and Steve,
I try to follow your way but it din't work   It's sure I have forgot
something ...
http://pofableau.com/openlayer/multicouche.html
the overlay code   is ok for *depart* and *calque *but without possibility
to scaling with panZoom.
It's the pb exposed in the beginning of this topic.
the overlay *départ2* who use your recommandation isn't visible on the map
I use this code :
Steve I wrote the following code for *depart* and *calque* but there is no
change for scale the Image as you can see. May be It's necessary to have a
time out for the script ?
Thank a lot  for your help.
Christian
View this message in context: http://osgeo-org.1560.n6.nabble.com/pb-with-map-getZoom-tp4982396p4982672.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120620/a3e8ba6d/attachment.html>
