[OpenLayers-Users] double buffered refresh of WMS layers
Meskanen, Vesa vesa.meskanen at logica.com
Tue Jun 26 00:58:09 PDT 2012
I am developing an application which includes two WMS layers, one baselayer and another translucent heatmap layer on top of the base layer. In the usual setup, layers seem to get  drawn one by one. My problem is that the heatmap layer modifies the color of the base layer quite much. When the update speed gets high (about 0.1 seconds/layer), the result is annoying flickering while modifying heatmap parameters interactively.
Is there a way to draw both layers at the same time (i.e draw both layers in a hidden back buffer and show the result when it is ready)?
All help is greatly appreciated!
Best regards,
Vesa Meskanen
Think green - keep it on the screen.
This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120626/f1178cfb/attachment.html>
