[OpenLayers-Users] Own map layer in different projection
Gery . gamejihou at hotmail.com
Wed Jun 27 01:45:23 PDT 2012
Hello,
and do you have some code about this problem?
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 27 Jun 2012 01:42:46 -0700
> From: shoppen at bananenhand.de
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] Own map layer in different projection
> Hi there, I need some help because I am stupid when it comes to projections.
> I would like to use OpenLayers with an own tile layer. That's fine so far.
> There are loads of examples in the web.
> BUT my tiles aren't in a Spherical Mercator projection, but – as my GIS
> colleague says – in a WGS84 / rectangular projection. The tiles are even
> bigger with 512x512px.
> I have found some projection examples, but I have no clue. I used the
> OpenLayers.Layer.TMS feature which at least showed up with some tiles, but
> - it was not displaying all of them and
> - markers for position testing are not positioned correctly.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Own-map-layer-in-different-projection-tp4984150.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120627/beac55d3/attachment.html>
