[OpenLayers-Users] PB V 2.12 and Layer.GML
Christian Bleau christian.bleau at gmail.com
Thu Jun 28 14:00:42 PDT 2012
Exactly,
If I call "./lib/deprecated.js" the code is working.
Sorry to ask for a  pb  false.
Christian
Le 28 juin 2012 à 22:15, Andreas Hocevar a écrit :
> My guess is that the reason for 2.12 not working with your code is
> that you are using the deprecated Layer.GML, which is not included in
> OpenLayers 2.12 by default. If you still want to use it, you have to
> include deprecated.js in your build.
> Andreas.
> On Thu, Jun 28, 2012 at 8:48 PM, christian bleau
> <christian.bleau at gmail.com> wrote:
>> Hi,
>> I meet a pb with the 2.12 version.
>> In this URL :http://www.pofableau.com/OpenLayers/villages.html
>> If I use the V 2.11 OpenLayers.js  you can see the layers.
>> If I use the V 2.12 that doesn't work .......... :((
>> I forgot something ?
>> regards.
>> Christian
>> the code:
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/PB-V-2-12-and-Layer-GML-tp4984663.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Christian
Pof at Bleau
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120628/2493e58a/attachment.html>
