[OpenLayers-Users] best way to show many static points
Toby Reinicke ramotswa at gmail.com
Tue Oct 9 13:07:44 PDT 2012
Ah ok. Some more information on your setup would be of interest. How do you build your mapbox tiles? Do you have a WMs server running? For my sins I haven't used mapbox much, and I presume you're pulling them in as a Tile layer? Passing in x,y,z params?
If I had these reqs I'd use geoserver in a heartbeat.
Toby
On 9 Oct 2012, at 20:55, Mike Ryan <m.ryan6000 at gmail.com> wrote:
> The problem with tiles in my situation -- and someone jump in here if this doesn't sound right -- is that they'd cover the entire state of New York from low to high zoom levels, like 10 to 17. We've done this just fine for a small part of NYC using MapBox, but it seems that to cover the entire state is cost prohibitive because we'd require such a huge amount of storage.
> Does that sound out of whack?
> The next strategy is to use tiles at low zoom levels and then switch over to loading points at the high levels.
> I'll mess around w/ the single tile idea you mention.
> Thanks
> On 10/9/2012 3:48 PM, Toby Reinicke       wrote:
>> Hey,
>> So what's the problem with tiles? Server side stuff is your only choice really. Not going to load those points into a browser.
>> If its tiles you don't like you can always call the openlayers layer as a single tile? Slow down the rendering a bit but will just create the one image...
>> Toby
>> On 9 Oct 2012, at 20:35, m1k3ry4n <mr at mry4n.net> wrote:
>>> I have a situation where I'm going to have hundreds of thousands of points,
>>> and I'm wondering what the options are for displaying them other than using
>>> Tiles. These points are static, I do not need to interact with them, move
>>> them around, etc. Any thoughts?
>>> PS: On a separate note, I'm posting this from Nabble. I've been trying to
>>> send messages to the list for a month and the don't seem to be coming
>>> through. Maybe it's a subtle hint. In any case, if anyone has any ideas on
>>> what might be going on there, please let me know.
>>> Thanks!
>>> Mike
>>> View this message in context: http://osgeo-org.1560.n6.nabble.com/best-way-to-show-many-static-points-tp5007504.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121009/a20749dc/attachment.html>
