[OpenLayers-Users] understanding and implementing Strategy.BBOX correctly
Puneet Kishor punk.kish at gmail.com
Mon Oct 15 13:11:42 PDT 2012
I don't quite understand Strategy.BBOX so I would welcome some help. My code is like so
    var vec = new OpenLayers.Layer.Vector(
        "Vector layer", {
            strategies: [new OpenLayers.Strategy.BBOX()],
            protocol: new OpenLayers.Protocol.HTTP({
                url: "http://path/to/data.json",
                params: {
                    "polygon": map.getExtent()
                        .transform(
                            proj.google,
                            proj.latlng
                        .toGeometry()
                        .toString()
                format: new OpenLayers.Format.GeoJSON()
            styleMap: new OpenLayers.StyleMap({
                "default": style,
                "select": new OpenLayers.Style({
                    strokeColor: "red",
                    strokeWidth: 2,
                    graphicZIndex: 2
    map.addLayer(vec);
    vec.setVisibility(true);
Now, the above works well if the map is loaded centered on a view whose `getExtent()` results in data. However, if the map is loaded centered on a view whose extent has no data, then no data are retrieved even when the map is then panned into the right extent. My understanding is that whenever extent changes, a new call is made, so it wouldn't matter if the initial extent didn't have any data. Once I panned/zoomed into the right extent, data would be retrieved and the layer rendered. However, that is not happening. What is the error of my ways, and how do I correct it?
Many thanks,
Puneet Kishor
