[OpenLayers-Users] Does OpenLayers provide a way to check if a layer is available?
Bart van den Eijnden bartvde at opengeo.org
Fri Oct 19 00:37:40 PDT 2012
For any layers that descend from OpenLayers.Layer.Grid there is a tileerror event which you can listen for.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Oct 18, 2012, at 7:55 PM, Rob Hyx <robhyx at gmail.com> wrote:
> Hello,
> I have an OpenLayers map with several 'base layers', and by that I
> mean I have a custom drop down implemented that allows toggling
> between various WMS and ArcGIS layers for the base layer. Sometimes
> the default layer returns pink tiles (the server issues a 500 error).
> I want to be able to switch to the next one when this is not available
> automatically. Does OpenLayers provide a way to do this, or would I
> have to write some custom code and check whether or not I'm getting a
> 'png' back?
> Thanks in advance!
> HYX
> http://hyx-music.com
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121019/2aece8d1/attachment.html>
