[OpenLayers-Users] Print map to pdf
Robert Sanson Robert.Sanson at asurequality.com
Wed Oct 24 08:23:48 PDT 2012
The approach I use is to collect the layers that are visible and the extent, and the then send a WMS call to a server to generate a new composite image which is then processed by a Python script on the server using ReportLab module to create a PDF.
Cheers,
Robert Sanson
>>> Mickey Bowles <mickeybowles at gmail.com> 25/10/2012 9:13 a.m. >>>
Can you gif or jpg the image, then use someting like itextsharp (if you are
a .net guy) to pdf or something similar?
On Thu, Oct 25, 2012 at 11:06 AM, Gaston Lucero <gaston.lucerom at gmail.com>wrote:
> It is possible with openlayers controls?
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
