[OpenLayers-Users] Print map to pdf
Tobias Reinicke ramotswa at gmail.com
Thu Oct 25 08:35:35 PDT 2012
I only really stumbled accross this a few days - not sure why not before.
In Geoserver 2.2 you can actually output a pdf via WMS request.
so normal WMS request with one or more layers in the "LAYERS=" parameters,
and then the format parameter is just: "FORMAT=application%2Fpdf"
Simple pdf creation.
Toby
On 24 October 2012 17:23, Robert Sanson <Robert.Sanson at asurequality.com>wrote:
> The approach I use is to collect the layers that are visible and the
> extent, and the then send a WMS call to a server to generate a new
> composite image which is then processed by a Python script on the server
> using ReportLab module to create a PDF.
> Cheers,
> Robert Sanson
> >>> Mickey Bowles <mickeybowles at gmail.com> 25/10/2012 9:13 a.m. >>>
> Can you gif or jpg the image, then use someting like itextsharp (if you are
> a .net guy) to pdf or something similar?
> On Thu, Oct 25, 2012 at 11:06 AM, Gaston Lucero <gaston.lucerom at gmail.com
> >wrote:
> > It is possible with openlayers controls?
> > Users mailing list
> > Users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> This email and any attachments are confidential and intended solely for
> the addressee(s). If you are not the intended recipient, please notify us
> immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted
> Security.
> www.websense.com
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121025/cc128c89/attachment.html>
