[OpenLayers-Users] Print map to pdf
Till Adams adams at terrestris.de
Thu Oct 25 08:39:03 PDT 2012
you alsy may have a look at mapfish-print module, which is also perfect
linked to geoext:
http://trac.mapfish.org/trac/mapfish/wiki/PrintModuleDoc
http://geoext.org/
See also GeoEXt example:
http://api.geoext.org/1.1/examples/print-form.html
Regards, Till
On 25.10.2012 17:35, Tobias Reinicke wrote:
> I only really stumbled accross this a few days - not sure why not before.
> In Geoserver 2.2 you can actually output a pdf via WMS request.
> so normal WMS request with one or more layers in the "LAYERS="
> parameters, and then the format parameter is just:
> "FORMAT=application%2Fpdf"
> Simple pdf creation.
> Toby
> On 24 October 2012 17:23, Robert Sanson <Robert.Sanson at asurequality.com
> <mailto:Robert.Sanson at asurequality.com>> wrote:
>     The approach I use is to collect the layers that are visible and the
>     extent, and the then send a WMS call to a server to generate a new
>     composite image which is then processed by a Python script on the
>     server using ReportLab module to create a PDF.
>     Cheers,
>     Robert Sanson
>     >>> Mickey Bowles <mickeybowles at gmail.com
>     <mailto:mickeybowles at gmail.com>> 25/10/2012 9:13 a.m. >>>
>     Can you gif or jpg the image, then use someting like itextsharp (if
>     you are
>     a .net guy) to pdf or something similar?
>     On Thu, Oct 25, 2012 at 11:06 AM, Gaston Lucero
>     <gaston.lucerom at gmail.com <mailto:gaston.lucerom at gmail.com>>wrote:
>     > It is possible with openlayers controls?
>     > _______________________________________________
>     > Users mailing list
>     > Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>     > http://lists.osgeo.org/mailman/listinfo/openlayers-users
>     This email and any attachments are confidential and intended solely
>     for the addressee(s). If you are not the intended recipient, please
>     notify us immediately and then delete this email from your system.
>     This message has been scanned for Malware and Viruses by Websense
>     Hosted Security.
>     www.websense.com <http://www.websense.com>
>     Users mailing list
> Users mailing list
NEWS:
-> Support OpenLayers 3 !
 http://openlayers.org/blog/2012/10/17/openlayers-3-call-for-funding/
-> GO Mobile - jetzt WebGIS auch auf Smartphones
-> Bald OpenSource! SHOGun - das JavaBackend für WebGIS Anwendungen
terrestris GmbH & Co. KG
Puetzchens Chaussee 56
53227 Bonn
Germany
Till Adams
Geschaeftsfuehrung
Tel:	+49 (0)228 / 962 899-52
Mobile:	+49 (0)151 / 25394429
Fax:	+49 (0)228 / 962 899-57
http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementaerin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
