[OpenLayers-Users] Unable to fetch data from user defined polygon
Smaran Harihar smaran.harihar at gmail.com
Thu Oct 25 13:23:25 PDT 2012
Hi Phil,
That is what I am confused about that it works fine but only for US States,
the e.features is an empty object.
If you see the application <http://128.196.142.55/geo/test/test.html>, and
click on the "draw poly" tool on top and select the US States layer and
draw a polygon over the US, the console says that the features are returned
but the e.features is empty.
While if you do the same and select Pima Pine instead, the table gets
populated. The same function is being used in both the case then why is
there a problem?
Thanks,
Smaran
On Wed, Oct 24, 2012 at 7:28 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> Both of those are good valid responses. What you need to show us is the
> response that comes back when it doesnt work. (or the status if you get
> no response at all).
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121025/e83369ae/attachment.html>
