[OpenLayers-Users] Kml layers "on the fly"
Phil Scadden p.scadden at gns.cri.nz
Tue Sep 18 14:40:45 PDT 2012
> At the moment there are 20 kml files but they're growing in number so
> I would prefer to have a single vector with the filenames in it and
> then cycle in order to add the layers to my map.
> Can I achieve this task? or should I write the relevant stuff for each
> kml file? Can I use an array prototype?
I use a json file which contains all the details about the layers I want
to add to a map and how they will behave. I have then coded an object
that reads the json and creates the maps from that. It gives me a
generic mapping application that I can use in many contexts.
(data.gns.cri.nz/dataportal - free registration required but there are 4
maps inside that application using this method).
I would worry about a lot of KML files. They are slow to transmit and
load. geoserver + postgis and sql views would allow you to do a WMS for
display, WFS for query which would be a lot more efficient as your data
size increases.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
