[OpenLayers-Users] one control panel - mixed control types - how to disable all others
karsten
karsten at terragis.net
Fri Sep 21 11:16:07 PDT 2012
For now found a solution that is working for me but seems that there should
be a better, more generic way of doing this.
I wrote a function to just turn off all other active controls (see below),
but that I need now to put into every control handler function to switch off
other active control. Using events , listeneeres and so forth there should
be a better way. How would you go about this ?
Cheers
Karsten
function deactivateToggleControls(){
for (eachControl in customToolPanel.controls) {
if (customToolPanel.controls[eachControl].active) {
customToolPanel.controls[eachControl].deactivate();
_____
Sent: Thursday, September 20, 2012 11:51 PM
To: 'openlayers-users at lists.osgeo.org'
Subject: one control panel - mixed control types - how to disable all others
Hi All,
I am not sure if it expected behavior if you have a panel with multiple
controls, some Type 'Button' plus others such as Control.MeasureNew and
Control.MouseDefaults that the last two deactivate once the other is
clicked, but the button type controls won't deactivate then ?
For example when the user clicks son the 'MouseDefaults ' control then
'MeasureNew ' is deactivated (if it was active previously) , however
clicking on any of the button type controls does not deactivate 'MeasureNew'
So I was wondering what is the standard / or best way to have the button
controls when activated , deactivate all other controls ?
Cheers
Karsten
Karsten Vennemann
Principal
Terra GIS LTD
<http://www.terragis.net/> www.terragis.net
Email scanned by PC Tools - No viruses or spyware found.
(Email Guard: 9.0.0.2308, Virus/Spyware Database: 6.20640)
http://www.pctools.com/
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120921/cd3d6ba9/attachment.html>
