[OpenLayers-Users] Why is mapserver layer not showing up in openlayers?
INDRA BAYU cucuberlian at gmail.com
Tue Apr 9 05:14:04 PDT 2013
I'm currently setting up a Mapserver/OpenLayers application. My
mapscript works fine when i run on mapserver, but my mapserver layer
not showing up in openlayers.
this is my script
===================== "tangsel.map"============================
MAP
  NAME "TANGSEL"
  STATUS ON
  EXTENT 106.636718 -6.363274 106.779904 -6.228827
  SIZE 885 600
  SHAPEPATH "../shp"
  IMAGETYPE PNG
  IMAGECOLOR 252 253 255
  UNITS DD
  PROJECTION
    "init=epsg:4326"
  END
  LAYER
      PROJECTION
        "init=epsg:32748"
      END
      NAME "tangsel"
      DATA "tangsel"
      TYPE POLYGON
      STATUS ON
      CLASS
          NAME "tangsel"
          COLOR 0 0 120
          OUTLINECOLOR 0 0 0
      END
  END
END
========================"index.html"=============================
var map;
function init() {
	map = new OpenLayers.Map({
		div: "map",
		projection: "EPSG:4326",
		displayProjection: "EPSG:4326",
		controls: [
			new OpenLayers.Control.Navigation(),
			new OpenLayers.Control.PanZoomBar(),
			new OpenLayers.Control.ScaleLine(),
			new OpenLayers.Control.MousePosition(),
			new OpenLayers.Control.KeyboardDefaults()
	// create Google Mercator layer
	var gphy = new OpenLayers.Layer.Google(
		"Google Physical",
		{type: google.maps.MapTypeId.TERRAIN}
	// create Mapserver layer
	var msv = new OpenLayers.Layer.MapServer( "SHP",
		"http://localhost/cgi-bin/mapserv.exe",
		{map: 'e:/ms4w/ppgt/map/tangsel.map'},
		{layers: 'tangsel', srs: 'EPSG:4326', isBaseLayer: false, visibility: true},
		{gutter: 15}
	// Key Map
	var keymap = new OpenLayers.Control.OverviewMap({
		maximized: true,
		maximizeTitle: 'Show the overview map',
		minimizeTitle: 'Hide the overview map'
	map.addControl(keymap);
	map.addLayers([gphy, msv]);
	map.setCenter(new OpenLayers.LonLat(106.716677,
-6.295165).transform('EPSG:4326', 'EPSG:3857'), 11);
	map.addControl(new OpenLayers.Control.LayerSwitcher());
does someone know what the problem is?
