[OpenLayers-Users] terrestris WFS not showing in OpenLayers
Tobias Kirschke tobias.kirschke at student.afg.hs-anhalt.de
Tue Apr 9 13:43:35 PDT 2013
Thanks for help, but the solution is:
You need to set "readFormat: new OpenLayers.Format.GML.v3()" in  new
OpenLayers.Protocol.WFS()
Am 09.04.2013 19:26, schrieb Gery .:
> komisch... perhaps this one can give you some more clues:
> http://stackoverflow.com/questions/9292911/proxying-apache-with-8081-port-to-geoserver-8080-for-wfs
> I use tomcat also but with apache and mapserver, so not sure if the
> problems can be related to geoserver itself, I'd say that geoserver
> needs some attention when using proxies.
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas
> si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt- bewahren Sie es auf dem Bildschirm. Drucken
> Sie es NICHT, wenn es NICHT notwendig ist.
> > Date: Tue, 9 Apr 2013 19:11:35 +0200
> > From: tobias.kirschke at student.afg.hs-anhalt.de
> > To: gamejihou at hotmail.com
> > CC: openlayers-users at lists.osgeo.org
> > Subject: Re: [OpenLayers-Users] terrestris WFS not showing in OpenLayers
> > I have a Tomcat 7 server and use proxy.jsp from terrestris for
> > OpenLayers-Proxy-settings. Firebug says no errors and the response is
> > valid XML (GML) with the geometries. But the geometries are not showing
> > in the map.
> > Am 09.04.2013 18:23, schrieb Gery .:
> > > Probably there is a conflict with your server (I'm guessing here),
> what firebug says?
> > > Sent from my iBath
> > > On Apr 9, 2013, at 14:01, "Tobias Kirschke"
> <tobias.kirschke at student.afg.hs-anhalt.de> wrote:
> > > Hi,
> > > I use a WFS from http://ows.terrestris.de/dienste.html in my
> OpenLayers application but the WFS is not showing. The Proxy-settings
> are correct. My code:
> > > var demo = new OpenLayers.Layer.Vector("WFS", {
> > > strategies : [new OpenLayers.Strategy.BBOX()],
> > > protocol : new OpenLayers.Protocol.WFS({
> > > version:"1.1.0",
> > > url : "http://ows.terrestris.de/geoserver/terrestris/wfs",
> > > featureType : "world-countries-shape",
> > > featureNS : "terrestris",
> > > srsName : "EPSG:900913",
> > > geometryName: "the_geom"
> > > styleMap: myStyles,
> > > With my own WFS from Geoserver I see the Layer in the OpenLayers
> map. What is wrong? Thanks.
> > > Tobias
> > > Users mailing list
> > > Users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130409/9b21dd10/attachment.html>
