[OpenLayers-Users] Whitespace in Value Passed to Filter
Jerome A. Wendell jawendell at suddenlink.net
Tue Apr 9 14:53:43 PDT 2013
I have a filter setup to be used on a WMS layer.  The filtered features are
being placed on a vector layer.  As long as the value that I pass to the
filter does not contain any whitespace, the filter works fine.  If the value
passed to the filter contains whitespace within it, nothing is returned.  I
am using Firefox with Firebug to test the map, and all of the values that
are passed to the filter are shown correctly in the POST command.  I know
the features exist, on the layer that is being filtered, that have the
attribute with the value that I am using that has whitespace.  Is there
anything that I can do to the filter so that the whitespace doesn't cause
the search to fail?  The applicable part of my code is below:
var filter = new OpenLayers.Filter.Comparison({
                type: OpenLayers.Filter.Comparison.EQUAL_TO,
                property: 'myproperty',
                value: 'myvalue'
wfsProtocol = new OpenLayers.Protocol.WFS({
                version: "1.1.0",
                url: "http://myserver:8080/geoserver/mystore/wfs",
                featureType: "mylayer", //name of the geoserver layer
                featureNS: "mystore", //name of the geoserver store
                geometryName: "the_geom",
                srsName: "EPSG:4326",
                scope: strategy
var strategy = new OpenLayers.Strategy.Fixed();
var response = wfsProtocol.read({
                filter: filter,
                callback: processWFSQuery
function processWFSQuery(response) {
try {
                                var gmlParser = new
OpenLayers.Format.GML.v3();
                                var features =
gmlParser.read(response.priv.responseXML);
                                vectorLayer.destroyFeatures();
                                if(features.length > 0) {
                                                for(var i = 0; i <
features.length; i++) {
        var feature
= features[i];
feature.geometry.transform(new
OpenLayers.Projection('EPSG:4326'),this.map.getProjectionObject());
vectorLayer.addFeatures(feature);
                                layextent = vectorLayer.getDataExtent();
                                map.zoomToExtent(layextent);
                                }else {
                                                alert("Not found!");
                                                if (popup){
popup.destroy();
                } catch(e) {
                                alert("Error: " + e);
Any suggestions are greatly appreciated.
Thanks.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130409/b348a542/attachment-0001.html>
