[OpenLayers-Users] Popup Error: Select is not defined
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Wed Apr 10 08:49:18 PDT 2013
There are only two OL classes that have this method `unselectAll`:
OpenLayers.Control.GetFeature and OpenLayers.Control.SelectFeature. So check
your code.
Regards,
boesiii wrote
> Xavier, that did not work. I received the same error message. I tried to
> set a global variable, var control_select;, but that gave me a different
> message, "Cannot call method 'unselectAll' of undefined".
View this message in context: http://osgeo-org.1560.x6.nabble.com/Popup-Error-Select-is-not-defined-tp5045606p5045854.html
