[OpenLayers-Users] Repeat WMS layer with wrapdateline option???
Gery .
gamejihou at hotmail.com
Wed Apr 17 06:27:34 PDT 2013
Hello Pascal,
very likely I would say, have you tried using both layers the same extent? ie. the extent that covers everything, I think it should be something similar to google layers when they are used as basemap layers.
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 17 Apr 2013 06:23:06 -0700
> From: pascal2833 at gmail.com
> To: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Repeat WMS layer with wrapdateline option???
> Thanks Gery for your answer!
> No, the layer which works come from our internal server (we use netCDF data)
> and the layer that doesn't work (contries's limits) come from an external
> server (knmi).
> But in the client part, I only defined the maxextent in the map constructor.
> Does that mean that is the maxextent of the external server doesn't match
> the maxextent defined in the map constructor, it couldn't work?
> Pascal.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeat-WMS-layer-with-wrapdateline-option-tp5047627p5047637.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130417/fd99ada5/attachment-0001.html>
