[OpenLayers-Users] Repeat WMS layer with wrapdateline option???
Gery . gamejihou at hotmail.com
Wed Apr 17 08:16:51 PDT 2013
Hello Pascal,
I meant the main maxExtent, the one that goes with "var map" etc..., and how about changing the extent in the server side? what is the extent of each layer? perhaps there is a problem about tiles.
Sent from my iBath
On Apr 17, 2013, at 15:59, "pascal" <pascal2833 at gmail.com> wrote:
very likely I would say, have you tried using both layers the same extent?
ie. the extent that covers everything, I think it should be something
similar to google layers when they are used as basemap layers.
Hello Gery,
You mean add in each layer.WMS constructor the same max extent information?
I've done it but it doesn't change anything.
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeat-WMS-layer-with-wrapdateline-option-tp5047627p5047658.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
