[OpenLayers-Users] Repeat WMS layer with wrapdateline option???
pascal pascal2833 at gmail.com
Wed Apr 17 08:39:55 PDT 2013
Hello Pascal,
I meant the main maxExtent, the one that goes with "var map" etc..., and how
about changing the extent in the server side? what is the extent of each
layer? perhaps there is a problem about tiles.
Sent from my iBath
Hello Gerry,
Yes, I've set the "main maxExtent" (in the map constructor). I suppose that
the countries's division layer doesn't have the same maxExtent  that the
other one and that it's not possible to repeat it if we apply a big
resolution (or a very extent zoom)
But how do you know  the layer's maxExtent (with getCapabilities?) ?
How do you change the extent in the server side (I can't access to this
external server)?
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeat-WMS-layer-with-wrapdateline-option-tp5047627p5047705.html
