[OpenLayers-Users] Repeat WMS layer with wrapdateline option???
Gery . gamejihou at hotmail.com
Wed Apr 17 08:56:20 PDT 2013
Hello Pascal,
I think that's the problem, perhaps it's not possible to repeat. I don't know how to get the extent, and I don't think you can modify the extent in server side if you don't have access to it, probably using some kind of URL (or Ajax?) you could get that.
Sent from my iBath
On Apr 17, 2013, at 17:40, "pascal" <pascal2833 at gmail.com> wrote:
Hello Pascal,
I meant the main maxExtent, the one that goes with "var map" etc..., and how
about changing the extent in the server side? what is the extent of each
layer? perhaps there is a problem about tiles.
Sent from my iBath
Hello Gerry,
Yes, I've set the "main maxExtent" (in the map constructor). I suppose that
the countries's division layer doesn't have the same maxExtent  that the
other one and that it's not possible to repeat it if we apply a big
resolution (or a very extent zoom)
But how do you know  the layer's maxExtent (with getCapabilities?) ?
How do you change the extent in the server side (I can't access to this
external server)?
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeat-WMS-layer-with-wrapdateline-option-tp5047627p5047705.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
