[OpenLayers-Users] Pointradius reduces at select icon
Andreas Hocevar
ahocevar at opengeo.org
Sat Apr 20 00:33:40 PDT 2013
You need to make sure that the pointRadius for select style or render
intent is correctly set. See e.g. the styleMap in this example:
http://openlayers.org/dev/examples/select-feature-multilayer.html
Andreas.
On Thu, Apr 18, 2013 at 3:57 PM, cmay <gufutomozytibyfe at tempomail.fr> wrote:
> Hi, When I select a Point Vector it reduces the pointradius (The assigned
> Icon gets smaller).
> How can I turn this off?
> This is the code I use for the selection:
> var selectCtrl = new OpenLayers.Control.SelectFeature(lyrmarkers);
> map.addControl(selectCtrl);
> selectCtrl.activate();
> lyrmarkers.events.on({
> featureselected: function(e) {
> createHtmlPopup(e.feature);
> featureunselected: function(e) {
> popup.close();
> regards, Chris
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Pointradius-reduces-at-select-icon-tp5047983.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
