[OpenLayers-Users] Having Google map api and arcGIS server. Anybetter ideas?
Arnd Wippermann arnd.wippermann at web.de
Mon Apr 29 09:35:51 PDT 2013
Hi Phil,
For WMS you doesn't need to overwrite getFullRequestString().
You have to set projection in the layer options.
Look at
http://osgeo-org.1560.x6.nabble.com/epsg-3857-and-google-900913-td5027619.ht
ml
Example
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/wms_options_projection.asp
For OpenLayers the projections
// list of equivalent codes for web mercator
var mercator = ["EPSG:900913", "EPSG:3857", "EPSG:102113", "EPSG:102100"],
are equal. If the layer projection equals the mapprojection, the layer
projection are used.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Phil
Scadden
Gesendet: Montag, 29. April 2013 06:22
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Having Google map api and arcGIS server.
Anybetter ideas?
ArcGIS Server doesnt like EPSG:900913 and maps doesnt like EPSG:3857.
Its a pain.
I got around this with a couple of overrides. Has anyone found a better way?
Ext.override(OpenLayers.Layer.WMS, {
     getFullRequestString:function(newParams, altUrl) {
         var projectionCode = this.map.getProjection();
         if((projectionCode == 'EPSG:900913') &&
this.url.search(/arcgis/)>=0) {
             this.params.SRS = 'EPSG:3857';
         } else {
             this.params.SRS = (projectionCode == "none") ? null
:projectionCode;
         return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(
                                                    this, arguments);
Ext.override(OpenLayers.Request, {
     GET:function(config) {
         if((config.params.SRS == 'EPSG:900913') &&
config.url.search(/arcgis/)>=0) {
             config.params.SRS = 'EPSG:3857';
         config = OpenLayers.Util.extend(config, {method: "GET"});
         return OpenLayers.Request.issue(config);
And for WFS protocol, create with:
     var srs = (currProj=='EPSG:900913' &&
source.serverUrl.search(/arcgis/)>=0) ? 'EPSG:3857' : currProj;
     if(spatialQueryNode.type=='wfs') {
             source.wfsProtocol = new OpenLayers.Protocol.WFS.v1_1_0({
                 url: spatialQueryNode.url,
                 featurePrefix: spatialQueryNode.featurePrefix,
                 featureType: spatialQueryNode.featureType,
                 geometryName :geomName,
                 srsName: srs
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St, Private
Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
